Question about Xerox Phaser 8400 Laser Printer
Fault code error message 04.024.45:60130 has appeared on the fronnt screen of Xerox Pahser 8400 printer. What does this mean ? Thanks
  • J3Brother Mar 24, 2009
    I have this same problem. This error code dela swith the wiper drive is not aligned properly. According to my repair manual, it says to run through different tests. You would have to access the diagnostics menu by first powering off the printer pressing and hold ing the "i" button and return button at the same time while turning the printer on and holding it for atleast 30 seconds. You will then access the Service Diagnostics menu. There you can perform the Check Wiper Alignment test and Wiper Drive test. If it fails, you may have to replace the Wiper Drive assembly.
    In my case it passes all the tests dealing with the wiper drive. I checked to make sure that the wiper is free and clear from the print head and that is clean. I also checked to make sure that all gears are lined up properly. But I still get this error code 04,024.45 displayed on the LCD after the warmup reaches 30%.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well..it's a system error code..is this an older machine, by chance?
Posted on Aug 20, 2008
I have a xerox phaser 8400 printer that will not do anything, just reads "fault 37,004.40:32046" what can I do? Thank-you
The 37,004.40 error means that the ink reservoir is not heating up correctly. Make sure the printer is plugged in directly into the wall and not on a power strip and cycle the power to the machine (turn it off and back on). If the problem continues, you probably have a bad printhead which you have to replace. For the 8400 the part number is 650-4303-00. Iteminc.com has that part in stock and ships same day. Here is a video that shows you how to replace the printhead. Hope this helps and thanks for using FixYa.
Aug 16, 2011 | Xerox Phaser 8400 Laser Printer
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Error message Xerox Phaser 8400 07.010.43.4819
The post was a little confusing. You have an 8400, correct? (not an M20)
The 07,010 error is normally a bad process motor 401-1000-80
You should also change 2 camshafts at the same time 401-1003-80 and 384-1874-80. The whole job is medium difficult and takes 2-3 hours.
Whit
Item, Inc.
May 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Phaser 8400 Error Code 07.009.42:265696
Hi carlt322:
Here is your problem.
7,009.4x: PM_FAULT_HEADTILT_PARK_ ERROR
The printhead is tilted back but not in the park arms and restrained properly. This is due
to the wiper assembly not moving up far enough for the park arms to hold it.
1. Check the printhead heater wiring.
2. Check for an obstruction or damage in the process
gearbox. Ensure the gears are correctly aligned and
homed, see page 6-8. If faulty replace the process
gearbox assembly.
3. Run the Head Maintenance Clutch test, if it fails replace
the clutch.
4. Run the Wiper Drive test. If the test fails, inspect the
maintenance drive system.
5. Replace the exit assembly.
Hope this helps
Sep 25, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error message 07,010.43:41
it may the lack in black ink or the ink unit would have been lost its frequency, check and clarify with a service engineer
Sep 15, 2009 | Office Equipment & Supplies
Xerox Phaser 8400 error code 37,004.40:27697
The majority of the time that code means the print head has failed.
That is a print head heater error.
You can find some places that sell print heads for about $150 , you would have to google the model number for that.
Xerox would charge $750 for a new print head, uninstalled.
Apr 24, 2009 | Xerox Phaser 8400 Laser Printer
Error messge xerox Pahser 8200 09.007.42:11683
The yellow ink sticks are jammed.
Open the ink loader and ensure that the yellow ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks.
Dec 07, 2008 | Xerox Phaser 8200 Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 fault
I have the same problem. Xerox says they need to send someone out and can not tell me what this code means.
Prior to the error I have having light streaking on the page. Took everything apart and cleaned and it worked OK for 2 days then returned to streaks.
If anyone knows what to look for please offer assistance.
Jul 24, 2008 | Xerox Phaser 8400 Laser Printer
Xerox 8400 error code 37,063.45
Vpp measurement too low.
The printhead power cable may be disconnected.
Xerox All error booklet download LINK
Please rate as Thankyou
Dec 26, 2007 | Xerox Phaser 8400DP Thermal Printer
Xerox Phaser 8400 Laser Printer Logo
372 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
