Wharfedale PowerCube PC-10 Subwoofer
Problem for Wharfedale PowerCube PC-10 Subwoofer
Wharfdale PC 10 subwoofer
By rmbjab on Aug 20, 2008
My subwoofer sudenly stopped working, the green light does not illuminate but when you turn the power off there is a definite clack which indicates power is going into the unit. Can you suggest what to do to get it working again.
Best Solution
posted on Aug 20, 2008
Helpful)
johnplemons
Rank: Master
Rating: 86%, 16 votes
Some basic trouble shooting is required here. First you need to see if it is a problem from your source or the sub. Try a different source to the sub-woofer and see if it changes the response. If still nothing on the sub, then most likely there is an issue with the amp or driver. Check to see if there is a fuse on the sub, if so, it could be blown. There could also be an issue with the auto switching circuit on the subs amp, in that case, it would need to be repaired in the shop. But before that I would check all of the connections to the sub, and also to the driver in the cabinet. If everything looks good, then put some type of source directly to the woofer to see if it works, if you get sound, then looks like the amp has a problem. Again a repair or replace issue.
john
Was this helpful?
Yes
No
Popular Solutions for Wharfedale PowerCube PC-10
Questions and Unsolved Problems for Wharfedale PowerCube PC-10
Do you recommend Wharfedale PowerCube PC-10 Subwoofer?
Answer
Answer
hi i have a wharfedale power cube 8. it cut out on me a couple of months back and didnt know why,... (More)
Answer
intermittent . does not always come on
Answer
my grandaughter pressed something and now the phone says unregistered. Ihave followed the... (More)
Answer
its been getting quite frustrating considering i've spent quite a bit of money on my sound system... (More)
Answer
Hello, Thanks for your support but main problem is i bought it in Abudhabi, UAE and now i am in... (More)
Describe your Home Theater Speakers and... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Home Theater... Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
