I have a Belkin 4-port router however the connections to my modem are different. I have a USB port on my Modem. Is there an adapter I can buy to get over this propblem?.
  • tandjdonnell Aug 20, 2008
    Spanet by telephone
  • IT aid
    IT aid May 11, 2010
    who is your ISP what connection you got ?
    President:
  • 2,961 Answers
No you can only use that modem from a pc, you need to buy a modem/router not just a router, unless you are on cable, but i assume you have a DSL connection
Posted on Aug 20, 2008
I have a new Kindle Fire. How do I connect modem to router to desktop
There should be a quick connect chart that came with your router!
However a router normally has 5 ports, 4 together and one separate from the other 4 and sometimes has a different color.
Unplug power from your modem, then plug the port on the modem to the one by itself on the router.
The 4 ports that are together are where you plug in up to 4 devices "Computers, Printers, Network Drives"
Now plug the power back into your modem and wait until the modem syncs back up to your provider.
Jan 14, 2013 | Belkin 150 N Router
Belkin F5D77230-4 - connecting to modem
It would seem that:
Your modem has only USB output;
Your Router has only Ethernet input with WiFi & 4 LAN port outputs; and
You want your laptop to be access the Internet through wireless connection.
There are USB to Ethernet converter/adapter, an example is shown here.
There are on the otherhand, comparable modems to what you have that provides both a USB and an Ethernet output such as the ProLink H9000 shown here .
Perhaps your best course of action is give your provider first a call and see if you can require them to replace your modem with another model/version, one that has an Ethernet output or a combination.
Alternately, a way can be configured if you have a desktop that has both a USB and Ethernet that we can set up as Gateway (but this is the long method).
Hope this be of some help/idea. Pls post back how things turned up or should you need further information.
Good luck and kind regards.
Nov 11, 2007 | Belkin (F5D7230-4) Router (587009)
Can I connect my USB Modem to my Belkin n300 Surf? do I need an adapter to connect it??
It is not possible to connect your USB modem to belkin router... You need to run an ethernet cable between the modem and router...
Belkin routers are not compatible with USB modems like cricket broadband, MTS Mblaze modem etc...
Jan 23, 2011 | Belkin Wireless Surf Router (F7D2301)
I cant connect to the internet
How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
I have a Huawei EC 168 usb modem from alltel and would like to know if it can be used with my belkin N+ router
inorder to connect to the belkin router you should have an ethernet outlet from the modem...even if it is an usb modem, go ahead and check whether there is an ethernet port...if there is an ethernet port, then connect it to the MODEM port of BELKIN router using an ethernet cable...if no ethernet port is found then it willnot be possible to connect to the belkin router...
because belkin router has got only ethernet port for getting connected to the ISP...
pls rate me if its useful...
Apr 03, 2010 | Belkin Computers & Internet
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
Oct 29, 2008 | Computers & Internet
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Need to hook up Belkin G wireless router to Motorola SB5120
Plug your cable line into your modem, make sure it's tight, but don't use a tool. Next plug the ethernet line from the modem to your PC ethernet port. Then plug in your power to the modem. Allow your modem to sync. Don't use the USB line at all. Do not even hook it up unless your computer doesn't have a working ethernet line. Don't run the disk either, it will only install the modem driver that is only used if you use USB.
If you have issues connecting after that, you may have to go into your ethernet adapter settings and make sure that it is using DHCP. DSL usually uses a different setting (PPP I think) and you will not be able to connect.
By the way, excellent choice in modems.
Jan 14, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
k ur modem is usb one either u need to change the modem has ether net or get a convertor like usb to ethernet better contact isp and change the modem rate me solved if its help full
Oct 30, 2007 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
David Payne
David Payne
