Question about HP LaserJet 1320n Printer
Printer i want to print test page not printing two lights flashing
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm..ok...turn off machine..let it sit for 3 min..then plug back in without computer connected..try it from front panel controls..you have the user manual?
Posted on Aug 20, 2008
6ya staff
SOURCE:
My HL2040 laser printer will print "Print Settings" page but otherwise will not print at all.
Set this printer as the default printer or if there are multiple printers connected or installed specify the printer issue print command
Jun 06, 2015 | Brother HL-2040 Laser Printer
Why is the light flashing on the right side
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
Jul 31, 2012 | Lexmark E250dn Laser Printer
Prints test copy every time I switch it on.
All right so you are getting print test copy every time you turn on or switch on your printer. You can follow the following steps to fix this issue:-
1.. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
let me know if it fix this issue and helpful to you.
Mar 03, 2011 | HP PSC 1510 All-In-One InkJet Printer
I just replaced both ink cartridges in my esp3 printer. But when I print, the page comes out blank
You need a new Print Head:
Clean the printhead, then print a test page.
  1. On the control panel, press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes. The On/Off light continues to flash during the cleaning procedure.
  2. When the On/Off light glows steady, press and hold Quantity + Cancel simultaneously until the On/Off light flashes, then wait for the test page to print.
  3. Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
    • Is the test page blank?
  4. 1-800-421-6699,Call Kodak to Report Code BP03
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 23, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a printer HP DJ 5940 and i have a problem with my connection. in status the printer says ready but when i try to printtest page says test page faild to print and i can't print. Any idea Manolis
Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
Aug 07, 2010 | HP Deskjet 5940 Photo InkJet Printer
Prints one or to pages then stops. Have to reset computer to get it to work. No test doesn't work. It is like it runs out of memory.
Try to run a test for continuous print test page in diagnostics mode. To enter the Diagnostics mode:
1. Turn off the printer.
2. Open the front access door.
3. Turn on the printer while pressing and holding Cancel .
4. Close the front access door once the Error light displays. Print the menu page by pressing and holding Continue until all of the lights flash. Follow the instructions on
the menu page to access the menu items.
Continuously print pages containing cross lines, printer information, and margin settings. Press and hold until the Continue button lights flash to begin. Press Cancel to stop.
Make sure he selects the "Cont Prt Simplex Tray 1" option
If problem persists, contact Lexmark at 1-800-LEXMARK()1-800-539-6275.
Apr 21, 2010 | Lexmark E260dn Laser Printer
Printer not printing model z2300 on light is flashing
replace the cartridges if the lights are continuisouly flashing. or if there is a pending document in the print que it will flash the lights.delete that pending documents.
Oct 23, 2008 | Lexmark Color JetPrinter Z23 InkJet
TLP 2844-z Flashing Red Light When I Try To Print
When the light flashes red, press the green button once. What happens then?
Oct 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
HP psc 1315v (printer, scanner, copier) Will not print
The test page printing out every time it gets turned on is the printer's way of telling you it wants to be calibrated. Lay the test page on the scanner (follow the pictures on the test page) and scan it in. This should fix that problem and the "occasionally after waiting, something prints" problem.
Unfortunately, I don't have an answer to the "E" on the display or check printer cartridge light. Hope this helps!
Sep 06, 2008 | HP PSC 1350v All-In-One InkJet Printer
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Thanks
Riz.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP LaserJet 1320n Printer Logo
82 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
