Question about APC Smart-UPS 1000VA UPS System
APC Smart-UPS RT 1000VA
Hello Dear Specialists
We have a problem with the APC Smart-UPS RT 1000VA: when we insert the power plug in the wall outlet in one way UPS make the short circuit, if we rotate the plug 180 degrees it is working ok. It is looks like that neutral is conected to ground wire.
So I would like to check with the circuit diagram for that device is it normaly or not. Could you please suggest where it is possible to find the circuit diagram for APC Smart-UPS RT 1000VA?
Best regards
Alex
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Posted on Jun 17, 2009
    New Friend:
Please u see the diagram apc1000va sua free
Posted on Mar 14, 2013
    New Friend:
  • 42 Answers
I have a complete diagram APC UPS
Dean Arhafidzia on Face book
Posted on Aug 27, 2012
SOURCE:
Overload problem
Hi Javier,
Is there a printer plugged into the UPS? If so, unplug it and plug it directly into a building outlet.
If not, you have to load manage what you can load the UPS with... remember it's only rated for 1000VA. Go here (http://www.apc.com/tools/ups_selector/) to get a better idea of what you need.
Reply or call if you need more help with this -- 800.260.2259
Sep 06, 2013 | APC Smart-UPS RM 1000VA USB (SUA1000RM2U)...
Apc smart 1000 ups after changing batteries all right are blinking
Is this the RT or the VT or the RM or the XL? Recheck the UPS's batteries by conducting a battery test. Press the I/Test button to initiate the battery test. If All LED are lit and the UPS emits a constant beeping then there is a internal fault.
FRONT PANEL LEDS FLASH SEQUENTIALLY: The UPS has been shut down remotely through software or an optional accessory card.
If all else fails then remove the input power. Unplug the batteries. Check the fuses in the back. If fuses are ok then push and hold the power button. This will reset the logic. Plug batteries back in, apply power and hopefully all is ok. If not then purchase another UPS the cost to repair it will be more then what it's worth
Sep 20, 2011 | APC Smart-UPS 1000VA UPS System
Problems with APC Smart-UPS 1000VA UPS System
Whenever you get problem with UPS call the concern technician for repair, you never try do any thing in UPS if you doesn't know about it.
Regards
Ashly
Feb 04, 2010 | APC Smart-UPS 1000VA UPS System
APC smart ups 1000va
Here we go again.. i encouter a lot of this problem. just change the whole front panel board and everything will work fine.
Jun 11, 2009 | APC Smart-UPS 1000VA UPS System
Apc smart ups 1000va does not work propery. when i switch on they make noise continuous so how can u help me plse.
UPS has an internal fault, ask APC to replace it if there still have a warranty or send it to service center for repair
Apr 29, 2009 | APC Smart-UPS 1000VA UPS System
My client has 19" in rack mount ups's circa 3kW. The building has generator back up however when we drop the mains and put the building on generator the ups do not see the generator hence stay on...
It sounds like someone wired your outlets wrong. I actually just found the same exact thing in my server room. All other outlets in our office are covered by our generator backup power except our server racks. I would suggest contacting the original electrician that installed the wiring to come out and check it again. Something is clearly wired wrong.
Dec 21, 2008 | APC Smart-UPS RT 1000VA (SURT1000XLI) UPS...
APC Smart-UPS 1000VA shut down and now will not power on. How do I troubleshoot? No power, no lights, nothing and I've never tried to troubleshoot a UPS before. Where do I start?? :-( Thanks Chris
Hello Chris,
I have a similar unit and there is a fuse inside that can blow. Mine did. It worked again after replacing the fuse.
Another option...check the battery connections.
Another option...are the batteries getting old? If so, when they won't reach a certain level of charge the unit will not power on.
Finally, make sure you don't have a blow fuse or popped circuit braker in your home.
Hope this helps?
Charlie
Nov 21, 2007 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1000VA is powered on but not working
Try turning the unit off for a little while, unplug it from the source even. afer about 5 minutes plug it back in and try it again. You may have a bad battery, how old is the unit. UPS batteries should be changed out every 3 year's, max every 5 year's if you want good reliability. At 5 years you are taking a chance.
Jan 18, 2007 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1000VA UPS System Logo
2,772 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Alun Cox
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
