Question about Navman GPS
When i switch my navman F series on it comes up whith a cross over the battery but it shows it as charging and will not go past the large circle of dots? please help???
  • 1 more comment
  • Harriergr7 Aug 20, 2008
    Yes the unit stays switched on, and the only way to switch off is to press reset button
    It only says Navman F-Series
    SV000279
    Canada 310
    Sorry can't offer any other help
    F20 is the make.
    I found this out by holding the on/off button and ^ button and restet machine and got message Navman F20 (32MB RAM)
    Primary Bootloader 4.10.002
    built on Jul 20 2006 at 13:09:00
    insert a sd into slot
    does that help??????
  • 13,433 Answers
Basicly that tells me you have a faulty or dead battery, does the unit stay on at all when unplugged? If the unit shuts off when unplugged this means you need to replace the battery in your unit.
please post your navman model if you require further assistance.
Thanks,
ekse
Posted on Aug 20, 2008
  • 2 more comments
  • Ekse Aug 20, 2008
    Whats the model? Il check for a software update.
  • Ekse Aug 20, 2008
    In the front of the device it should say F10 or F50 for example.
    Software updates are available on the navman pages, don't install a update if its not ment for your device
    http://www.navman.com/Navman/Templates/s...
  • Ekse Aug 20, 2008
    Yes that does, here is the update
    http://www.navman.com/Documents/InCar/so...
    F-Series only (F20, F30, F40 or F50, NOT F10).
    Please note that a USB cable (not supplied with the product)
    is required to connect your device to a PC in order to apply this
    update.
  • Ekse Aug 20, 2008
    if that doesn't help at all you can send a support request directly to navman they will know exactly what is wrong.
    use this page CLICK HERE
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
My navman won't charge or turn on, any ideas?
screen shows computer to navman all the time
Jul 25, 2010 | Navman F20 GPS Receiver
Navman 40i appears to charge up but will not
if the unit is more than 2 years old the chances are the battery is defective/worn out, you say battery appears to charge up, so think you are unsure of the battery condition.
Sep 11, 2009 | GPS
Navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Jun 10, 2008 | Navman F20 GPS Receiver
Battery Charging Navman S90i
The problem is that most of the chargers have the output of 5V/0.5A. The charger for NAVMAN (C30 in my case) has 5V/1A. And that is causing the trouble. The GPS is undercharged and is switching off itself. Buy one which specify the output power: 5V/1A. Hope I solved your problem
Feb 04, 2008 | Navman F20 GPS Receiver
Navman S50
My Navman S50 has been working fine the other day it decided to show me the safety agreement when switched on then shows half the screen black with navman S50 printed in the black section the other half shows a picture of a pretty womans face looking backwards from a car window. I can get to the main menu and then takes me in a circle back to the safety agreement I've tried resetting by holding the on off switch down for 6 seconds when switching off the device is there any other way to reset my navman S50.
Dec 30, 2007 | Audio Players & Recorders
Cannot switch navman on
I have a S30 Navman I was using it , when I got to my destination I turned it off when I went to turn it on to go back it will not turn on no picture or anything
can you help me please thank you
Dec 30, 2007 | Navman NavPix N40i GPS Receiver
Navman f10
i was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
pamelathanson@aol.com
Dec 28, 2007 | Navman Tracker 5500i GPS Receiver
GPS Logo
1,021 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
