Question about Lexmark P3150 All-In-One InkJet Printer
Lexmark printer how do we do a copy not a print
The Lexmark P3150 will not do stand alone copies. It must be connected to a PC to copy.
Posted on Aug 26, 2008
  • Lexmark Master
  • 13,434 Answers
Do you want to do a copy of a document directly from the scanner? OR copy a document to your pc?
If you want to do a copy - print it out directy, just press the copy button on the printer / scanner, this is covered in detail in the user manual.
IF you want to copy the document to your pc you need to press the scan button or open a program on your pc, for example microsoft paint - and get from scanner or camera.
Posted on Aug 20, 2008
4 Suggested Answers
SOURCE:
SOURCE: Lexmark x1185 printing problems
my lexmark will not print in color
Posted on Jan 30, 2008
SOURCE: My Lexmarks X5150 printer wont print out and copy
my scx-4521f has problam 3rd copy stop without paper jam ?
Posted on May 27, 2009
wayneard
  • 1901 Answers
SOURCE: How many copies will the Lexmark Z600 print out?
Specs say 10PPM black and 8PPM color in quick mode.
If you use higher resolution it will be reduced accordingly.
Refer to:
Z600 Series Specs
That is for a Z601, but the 600 should be the same.
Thanks for using Fixya.
Posted on Jan 01, 2010
Lexmark pro 900 will not print properly or copy or scan
There is a firmware update for the Lexmark Pro900 Series printer that addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark Pro900 Series Firmware Update.
After successfully updating your printer, try to print, scan or make a copy again to verify that the problem is fixed.
Should the problem continue, it might be a printhead problem. Please contact Lexmark Technical Support Center for further assistance.
Dec 29, 2011 | Lexmark Office Equipment & Supplies
Lexmark 510 series printer will print one job,
Hmm...Likely a driver issue. Try downloading a new driver (more up-to-date. Remove the old driver first (Need help? Look on the net for 'Removing Printer drivers') I suggest unplugging the printer before installing the new driver as well.
Here is the driver site:
http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&productCode=&segment=DOWNLOAD&question=driver+for+lexmark+510+printer
(Hint: Copy the whole link to notepad, make it all one long sentence, copy again and past into your browser)
Lexmark uses a dedicated 'Print spooler' that may be having issues. Ask a techy friend for help with this.
Mar 20, 2010 | Lexmark Z515M InkJet Printer
Printer is not printing - i have started, restarted diagnosis tests, changed the ink, uninstall and installed program. I have a Lexmark X2600. It says that it's ready; but still doesn't print? what else...
Check the USB cable to make sure it is connected, then restart your computer. Sometimes the computer registers it on a different USB port. When you go to print look at your printer options, is there a Lexmark and a Lexmark (copy 1)? Try printing from Lexmark (copy 1) if it is showing. If there is still a problem, try putting the print on another computer, to see if the printer is malfunctioning. If that is the case, you'll need to get another printer.
Sep 14, 2009 | Lexmark X2600 InkJet Printer
Lexmark model X4580. Prints 3 copys every time .
When you want to print, the Print window appears showing your printer, there is a box where you can select the number de copies.
Hope it helps
Sep 05, 2009 | Lexmark Office Equipment & Supplies
My Lexmark X75 will print but not copy. When I
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print. Are you copying from the button on the X75 or from the All-In-One Center software on the computer? If the button, try it from the software.
Feb 24, 2009 | Lexmark X75 All-In-One InkJet Printer
Can't get Lexmark X5410 to print. Printer is on "Copy Mode"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark P3150 All-In-One InkJet Printer Logo
87 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
