Thanks for help on Hitachi VCR not registering tape load :-)
Shuttle83.
Many thanks for the advice on Hitachi VCR not registering tape load, sounds like my issue.
I've noticed a perspex-like post on the main-board, almost as if it's afibre optic(?) that pokes up into the hole in the base of each videocassette - almost between the spools? There's no visible light that Ican make out from the thing.
Will investigate and if easily available will see if I can replace.
Regards,
Neil
  • yellowwestie Aug 20, 2008
    Shuttle83.
    Ah, thanks for the advice.
    No experaince of working at component level. Will see if I can figure out measuring supply voltage with my multi-metre - but no way of checking actual IR. If a new sensor's cheap enough will just swap to prove.
    Thanks,
    Neil
    Genius:
  • 1,139 Answers
Hello yellowwestie,
You will not be able to see the light because it is Infrared. But if you could get an IR meter you could test it, another way is to use a schematic and a voltage meter to measure the bias voltage on it.
Posted on Aug 20, 2008
HITACHI vcr DOES NOT LOAD TAPE
It's more than likely a slipping belt in the tape mechanism
If you are technically inclined it can be fixed for around $3.00
If you are not then it would be advisable to buy a new VCR because the repair cost would be more than the cost of a new one .
Mar 27, 2009 | Hitachi Televison & Video
VCR Stops on me
Hello Ro Power,
This might be due to the tape sensor malfunctioning. You will need a schematic, and multimeter, and a LED power meter to work on this problem. When the tape loads it causes an LED sensor to become blocked and then the sensor tells the control chip that a tape is present and the the controll chip allows the tape to continue playing, if the sensor does not work the signal never gets to the control chips and since other events happend and triggered the control chip the control chip looks at this as an error and the stops the tape , some units even eject the tape.
If you do not have a background in electronics, I would suggest that you take the VCR to a qualified shop and have them repair it.
I hope this helps,
Thank You,
Shuttle83
Oct 17, 2007 | Quasar VHQ940 VHS VCR
MAGNVOX MWR20V6 VCR WON,T ACCEPT TAPE EJECTS WONT LOAD UP
Hello alhertel,
The old idler wheel has been replaced with gears (cheaper and last longer then the old rubber wheel). What you need to do is to gain access to the loader motor and turn it until the carriage begins to move, once the carriage gets to the top and moves outward you should be able to eject the tape with no problem.
Believe it or not VCRs are throw away technology, since it costs as much to repair one as it does to buy a new one. However, there are a lot of people who still hold on to their VCRs.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 12, 2008 | Philips VRA611AT VCR
Will not load tape
Hello yellowwestie,
You may have a bad tape position sensor assembly (LED and photo transistor). It's purpose is to detect where the tape is in the loading process, and if the tape is not in the proper place at the proper time the tape is returned to the cassette and the cassette is ejected. This sounds like what you are talking about. I would suggest getting a schematic and checking the bias voltages (with a multimeter) on the tape position sensor assembly. If the sensor is bad replace it, if it is not check the tape sensor assembly circuitry.
I hope this helps
Thank you,
Shuttle83
Aug 18, 2008 | Hitachi Televison & Video
Tape won't stay in and play
The carriage might be misaligned because the tape is not even loading, in addition it may be one of the tape position sensors are going bad. These are the common reasons for this problem happening.
I hope this helps,
Thank you,
Shuttle83
Jul 16, 2008 | Philips Televison & Video
AUDIOVOX VCR SER#S9AA02677 MOD#AVP7000
Hello mountain8,
It sounds like the dew sensor might be bad and giving a false reading. If you have the ability to you could disconnect the dew sensor to see if it is the problem.
I hope this helps,
Thank you
Shuttle83
Jul 15, 2008 | Televison & Video
Tape is not threading
Hello optasia,
Check to see if the gear or wheel is engaging the capstan.
This more then likely is your problem.
I hope this helps,
Thank you,
Shuttle83
Mar 07, 2008 | Sony DSR-45 Mini DV VCR
Hello haroon2008,
I hope this helps,
Thank you,
Shuttle83
Jan 17, 2008 | Sony DSR-45 Mini DV VCR
Tape stuck in vcr
Hello tcsabug,
First locate the load and unload motor, it is the one with the rubber drive band. release the drive band and rotate the gear to raise and pull the carriage back into position.
This should remove your cassette, and put the carriage back into position.
I hope this helps,
Thank You,
Shuttle83
Oct 16, 2007 | JVC HR-J633M VCR
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
