Question about Samsung SF 835P Fax Machine (SF-835P/XAA) -6939 Printer
Fax i have a new printer, CLX-3160FN . it is networked with my two computers. When a phone rings, it goes to FAX after two rings. How do i stop the FAX from responding. I do not use fax at all. I don't need it. Thanks Lissa
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmmi...is the phone connected to the printer? if so, just disconnect the phone line from printer.
Posted on Aug 20, 2008
Trying to send a fax--it rings and rings, but never connects.
Are you certain you are faxing to a valid number. First verify by using another number that is a known working number and ask if it is ringing on the reception fax.
Feb 15, 2011 | Samsung CLX 3160fn All-In-One Printer
Cant receive faxes
Did you try to check the toner?
Try to print if the copy is lighter than before or it cant copy or print then you need to replace your toner cartridge.
Hope it can help you. (" ,)
May 22, 2009 | Samsung CLX 3160fn All-In-One Printer
No fax
le estas poniendo el cable de telefono en el roto equivocado, tienes que usar la linea regular de telefono, de lo contrario tendrias que tener un network ya setiado para ello con una pagina tuya, aparte poner el disco de network y configurar la pc para que lo registre y configurar el printer tambien, asegurate que el numero de fax funcione.
Apr 30, 2009 | Samsung CLX 3160fn All-In-One Printer
I have a samsung CLX 3160 Multifunction Fax. I have had the fax for a while and typically have no problem in receiving a fax. I need to know which one of the ports to put my phone line in that goes to the...
Hi again,
For some reason I could no longer view your responses.
Nonetheless, I posted in the Live Session a method of verifying the fax sending capability even in the absence of a receiving fax machine.
Cheers.
Dec 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Fax interrupts phone call
1. Make sure your [RINGS TO ANSWER] settings are more than the same settings for your answering machine.
2. If someone tries to make a copy while the phone line is in use, they need to press number 1, as if telling the unit that they want one copy. If not, the unit will think you are trying to receive a fax and will interrupt the communication.
Be blessed.
Sep 04, 2008 | Samsung CLX 3160fn All-In-One Printer
CLX-3160FN SAMSUNG Printer/Scanner/Fax
Replace your USB cable with a good quality, thick USB cable that does not exceed 10ft. Let me know if the problem persists.
Be blessed.
Aug 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
Stop the Samsung CLX 316FN from answering the house chat line
Make sure that the unit is hooked to the fax line only. Many people often merge both lines when connecting answering machines and more than one wireless phone. Also make sure that the unit is the FIRST equipment connected from the wall outlet. Finally, enter the program mode and make sure the fax setting is turned to FAX or TEL. The first setting makes the unit answer after the amount of rings programmed, while the other setting is for manual reception only. One final notice: if you are using the phone line for talking and someone hits START for a copy, the unit will assume a fax and iterrupt the communication. To avoid this, press NO. COPIES first before making copies. Even if it is for one copy only.
Oct 04, 2007 | Samsung CLX 3160fn All-In-One Printer
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
