Question about Nokia 3110 Cellular Phone
Mermory code lock
Please find it mermory lock in my phone nokia 3110
  • anuraggarg19 Aug 24, 2008
    I have same problem about the same. i need the solution of find the password of Memory card in Nokia 3110C
Pckesavaraju
Posted on Aug 25, 2008
My Nokia 3110C is requesting for a RESTRICTED CODE. It says that the phone is restricted. Could you Please Help Me???
Hi, You can get the restriction code for a Nokia 3110 Classic from www.classicunlocking.com/nokia-3110-classic/rs16wp9/ at low cost.
UNLOCKING STEPS FOR NOKIA 3110 CLASSIC
1 - Switch on your Nokia 3110 CLASSIC without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3110 CLASSIC.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3110 CLASSIC would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3110 CLASSIC mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3110 CLASSIC
Oct 30, 2012 | Cell Phones
Nokia 3110 undo restricted code
SIR MY PHONE USED IN NOKIA 3110 C .PLZ SIR RESTRICTED CODE NUMBER
Dec 17, 2011 | Nokia 3110 Cellular Phone
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
I need nokia's codea
Whether it's asking for Network Unlock code or security/password unlock code ?It asks for security /password unlock code means get from service provider and Unlock it,it asks for Network Unlock code means get the Nokia 3110 Model Phone Network unlock code at here
Classicunlocking.com/nokia/rs17wp8/ and Unlock it,Follow the instructions below and enter the Unlock code step by step....
Nokia 3110 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia 3110 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 3110 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 3110 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3110.
4 - The Nokia 3110 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3110 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
Each Nokia 3110 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 3110 mobile phone using the form above.
Aug 28, 2011 | Nokia 3110 Cellular Phone
Sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
What is my restriction code. nokia 3110. IMEI no. is 356789020560619. kindly provide the same at the earliest pse.
May i know it restricted by Which Network In which Country?
If you could provide those Details means i will check and tell is there unlock service for Model or not,!!!You can check and get Restriction code for Your Phone at
Superunlockcodes.com at Low cost and Follow the instructions to remove the Network Lock step by step:
Nokia 3110 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia 3110 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 3110 mobile phone, your phone may get hard locked and sometimes become unusable.
May 25, 2011 | Nokia 3110 Cellular Phone
NOKIA 3110 MAMORE CARD LOCKED FORGET PASSWORD
press oooo or press 1234 also 12345 works
Nov 13, 2009 | Nokia 3110 Cellular Phone
Mermory code lock
Select the memory card folder and Options > Set password. The password can be up to eight characters long. The password
is stored in your device, and you do not have to enter it again while you are using the memory card on the same device. If you
want to use the memory card on another device, you are asked for the password.
Aug 20, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 classic security code
imei 356975/01/265107/4
master code 0461441705
May 20, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
