Question about Cell Phones
I bought a dual sim card mobile but the strength signal for sim 2 is always v.bad and much time drop down. although both sim are from same provider. shall i send it for repair or all dual sim cards mobiles are same??
    Guru:
  • 179 Answers
It is a mobile from china normally u will face this problem wiz zis mobile
Posted on Sep 03, 2010
6ya staff
SOURCE:
Phone is locked emergency calls only
Did you mean your new used phone shown Emergency calls only while inserting your metro pcs sim card?
Yes means, There are two possibilities to get this type of issue.
1.You mobile phone receives weak signal from near tower so try to Switch off your mobile,wait few seconds and switch on.
2.Your mobile is locked to particular network provider.
If your problem persists after switch on your phone means definitely your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit http://www.theunlockspot.com/samsung/rs10wp8/ I hope it will be very useful to you.
Sep 11, 2014 | Samsung SGH Cell Phones
Nokia e5 network
What's your Network Provider?What's your Nokia E5 Network Exact Problem?
1.Is your mobile Network has Lower signal or No signal?
You can try to switch OFF your mobile and switch ON to check Network strength.
2.Is your mobile display show "NETWORK ERROR" message?
You can try to check the below instructions:
1.Reinsert SIM in your mobile
2.Insert another SIM in your mobile
3.Insert Your SIM into another mobile
3.Is your Mobile Network Locked?
You can easily unlocked your mobile by using unlock code.You can contact your service provider and get the code.If they will not provide the code..You may look at safe and trustworthy online third party code providers, like Unlock-Zone.com where they will provide permanent unlock code with free unlocking instructions..Then you can use this code to easily unlock your mobile.
Apr 25, 2014 | Cell Phones
Network problam
What's your Network Provider and Exact Problem?
1.Is your Samsung GTB7722 Network has Lower signal or No signal?
1.Reinsert the SIM your mobile
2.Another SIM insert your mobile
3.Insert your SIM into another mobile.
You can easily unlocked your mobile by using unlock code.You can contact your service provider and get the code.If they will not provide the code..You may look at safe and trustworthy online third party code providers, like Mobile-Unlocker.com where they provide permanent unlock code..After you get the code visit MobileUnlockGuide.com for free instruction on how to use that code to unlock your mobile.
Apr 16, 2014 | Samsung GTB7722
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
Bad signal i9 3g
maybe your phone signal probleam so better u add your phone signal boost up strip u can buy it and if u put it inside your mobile signal will be ok
good luck
Jul 14, 2009 | Dual Electronics CECT P168 Cellular Phone
Network problem. Call drops
your phone need to master reset. do if it is possible or just check your network by changing your sim card with an another phone. so that you can ensure that your mobile service provide provides you the exact service at the place from when you have problem
this can solve the problem
regards
ketan patel
Feb 02, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Data card won't work with antenna
sir i am having 64 bit laptop but i am not able to install my pc suit . what i should do?
Jun 25, 2008 | Computers & Internet
Anylink N99i dual sim mobile phone
setup > call setup > line switching
i guess u can use just one line at a time
u can't put them both on at the same time
let me know what happens.
Feb 15, 2008 | Cell Phones
Poor reception
1.Sometime due to bad antena, the signal receiving power goes bad, to confirm this, try another sim card in ur handset.So go to service centre to repaire or change the antena of ur handset.
2. Select network manually.
3.Try once ur sim card in diffrent area and in diffrent handset.
Sep 19, 2007 | Samsung SGH-D600 Cellular Phone
Cell Phones Logo
189 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
