Question about Admiral Refrigerators
On an Admiral GC2224Gekw the air management door between the refrigerator compartment and the freezer remins closed evn though the compartment temp is 17Deg C the freezer is at -18Deg C . If the servo is reset to open the door it closes it after approx 30 Seconds
  • Admiral Master
  • 19,396 Answers
The air duct between fridge and freezer on many models is managed by a chip module controlled by a termic sensor that activates a fan.
If it is a fan system, check that the fan is starting.
If it is not working start defrosting the unit, by leaving it unplugged overnight. Often the problem is caused by ice.
If it still does not work you need to test and eventually replace one of the following parts:
termic sensor
fan motor
fan solenoid
main control module (on some models)
If you cannot fix it with defrost, unless you are an expert DIYer I suggest calling in a technician. You can find a service contact number printed inside fridge owner manual.
If you are satisfied with the solution, please vote the solution.
If you are not satisfied you can Ask help from more experts.
Many thanks
Posted on Aug 20, 2008
    Brigadier General:
  • 6,966 Answers
Pls reference this page and look over the part number/description of the "air management door", might it be the "damper/cover"?
To my understanding, there is as you posted a servo controller termed "Damper Controller" that is responsible for the opening and closing. However, this damper controller takes its cues from the main controller/logic board that decides when to open or close based on its sensor readings. the wiring diagram might be of help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 13,433 Answers
It may be a fault in the circuits I would have the refrigenerator inspected.
You can find replacement parts from
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
And general support information with a few solutions to diffrent issues can be found here
http://www.repairclinic.com/0047_4.asp
here you can read about the issues and solutions
http://www.repairclinic.com/0088_4_1.asp
Freezer ok fridge not cooling
check the damper vent door between the refrige and freezer compartment and make sure its not frozen shut and the refrige control that you set the refrige temp with is opening and closing it correctly as this door channels the cold air in from the freezer
May 16, 2010 | Zanussi ZX97 / 5 Bottom Freezer...
The freezer is freezing but the refrigerator is not getting cold why?
check the damper door vent located between the refrige and freezer for being iced up and stuck shut,if cold air from freezer can't get past thid door the refrige will warm up,if this isnt the problem,adjust the refrige temp control and watch and see if this makes this door open and close as you adjust the temp of the refrige compartment
Apr 03, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer gets cold refrigerator doesn't
check the damper door located between the freezer and refrigerator compartments(this lets in the cold air from the freezer) and make sure it opens and closes with your temp adjustment in the refrigerator compartment,sometimes they ice-up and are frozen in one position then take a hair dryer and defrost the door
Mar 13, 2010 | Maytag MTF2156GEW Top Freezer Refrigerator
GE Monigram Ref, main food comparment stuck at 25 degrees
is your damper door between the freezer and refrige compartments opening and closing as you adjust the temp settings,they can become stuck open by ice build up,defrost the damper door and see if it closes then
Jan 16, 2010 | Refrigerators
Refrig side not cooling, freezer fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
I have an admiral GC2224GEKB
You may have to open the door to let the dispenser thaw since it's in the door.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 03, 2009 | Refrigerators
Side by side refrigerator
- Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
Feb 05, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
196 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
