Question about Samsung Refrigerators
Model SRS614DW Problem is as follows, Beeper sounds and Refrigerator Temperature goes up and down the scale, this can happen as much as ten times a minute Fridge temperature remains at the set level . this problem can last for two to three days then functions correctly for three weeks
    Brigadier General:
  • 6,966 Answers
Based on your description, a couple of things you can try:
  • evaporator on the fridge side may need thawing/cleaning;
  • replace the Evaporator Cover Assembly. Samsung has long replaced this original design/component (Jan 2007);
  • check for fan/blower action. They may be frozen, stuck or providing insufficient air flow.
This page might shed additional insights/related information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 20, 2008
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
Why is hi temp alarm sounding
Hello friend, thank you for your post!
Your high temp alarm will sound once your refrigerator temperature rises to an unstable temperature on the inside of your appliance. If you refrigerator is cooling properly I would recommend resetting your appliance which can be done by disconnecting the power to your appliance for roughly ten minutes. If this does not correct the issue, I would recommend having a professional come and diagnose your appliance properly. Hopefully this is helpful. -Matt
Sep 01, 2014 | Frigidaire StandardDepth Side-By-Side...
I have a ten yr. old Sub Zero model 642. The
maybe a re-gas will last another ten years...if the leak is that small a re-gas will probably last it days out....ask the service man to re-gas it so the food does not spoil until you can save up for replacement...then just see how it goes.
Jul 21, 2010 | Sub-Zero 690 Side by Side Refrigerator
LG LFX25960SW Refrigerator--Display goes bizerk
It is going thru a diagnostic process, But this is only to happen when you either open the circuit board and press the test button, or use the front display keypads. I would have the circuit board checked
Jul 27, 2009 | LG LFX25960ST Stainless Steel French Door...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer temperature is not consistent
No recall that I have on my listing for that model. Keep in mind that the refrigerator goes into a defrost mode that lasts up to 30 minutes. It happens anywhere from 10 hours to 60 hours of operational time. When this happens, it's not uncommon to see 20 ° temperature. If you check it again an hour later, it should be back under 10 °. Also, double check to be sure the condenser coils are really clean. That alone can also cause this sort of symptom.
Oct 24, 2017 | GE Refrigerators
FPCE19TR frigidaire refrigerator/freezer door beeping at odd times
Hello delgrandma
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your refrigerator has a sensor for when the door is not closed but lately the beeper goes off at various times and the door is shut. Your husband has tried to level up the door and you don't see anything keeping the door from shutting securely. The beeper even goes off in the middle of the night.
This sounds like the alarm switch or sensor is malfunctioning.
Do you have a refrigerator thermometer? You can buy one in the hardware store pretty cheap.
If so put it into the fridge and make sure the temperature is steady and not fluctuating.
If it fluctuating this may set off the alarm if it is a sensor that triggers the alarm due to temperature drop..
Rather than a mercury switch will only signal the false door opening if it is faulted, rather than a warm temperature!
How old is the fridge?
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Let me know what you decide!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Frigidaire FRT15B3A Top Freezer...
Wash temperature scale
TEMPERATURE - CELSIUS OR FARENHEIT
If you want to change the temperature indication from Celsius (C) to Farenheit (F), proceed as follows:
Turn the main switch, off and turn it on again. Press the Enter button five times, then press the P2 button five times. These ten times must be completed within fifteen seconds. Within three seconds after pressing P2 the last time, use the < > buttons to select temperature indication.
Sep 22, 2008 | Asko W640
Refrigerator side not cooling - freezer side icing up
It sounds like your defrost system has failed. There is a timing device that turns on the defrost heater(s) which may have stopped working. Or the heaters or defrost thermostat could be bad.
My suggestion is to find a different repair person who is qualified.
May 30, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
211 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
