Question about Magellan GPS
I tried to upgrade my Magellan Maestro GPS 4250 with the new firmware that Magellan sent. In the process, I accidentally erased all my data in my 4250 and now inoperable. Please help. Thank you.
  • gcg4ever Aug 20, 2008
    I have the original DVD that came with the system but it's only an instruction in a PDF format and it also connects you to the Magellan website. Thanks for the suggestion anyway.
  • 6,487 Answers
Try to reset it follow this:
The reset pin is located on the bottom of the Maestro 4250. Using a paperclip or something similar, press the reset pin for 15 seconds to reboot the GPS.
Hope that helps........
Posted on Aug 20, 2008
    Genius:
  • 1,689 Answers
If you still have the original DVD that came with the device, i think you can use that to upload them maps and other info, but of course this will just be like having the device brand new.
  • marlon john madrid
    marlon john madrid Aug 20, 2008
    the dvd i was referring to was the original source of the default maps in your magellan, if it is not available anymore, please try marked's solution, keep us posted for further troubleshooting
Hey I want to updating maps or software for magellan maestro 4250, but i can not found the right software for it,so pleas can you help me,thank you.
Hi muntaserabou
you can get the latest firmware 4.86 for your 4250 HERE and the
2010 Map update for it HERE
Nov 27, 2010 | Magellan Maestro 4250 GPS
I was trying to download the new upgrade and my screen is locked. it just says magellan. it's a 4250
it is possible to lock other operations while system is heading for upgraded one
Dec 14, 2009 | Magellan Maestro 4250 GPS
Firmware Update 4.86 failed in mid-update. Maestro 4250 will not respond. Menu screen comes up but will not work.
try and run the firmware update again. make sure the its fully charged or plugged in. this usually works though sometimes it wont depending on what files are missing..they are other ways to fix this problem, but i recommend you call magellan to get it fixed. they will repair any of their gps that were rendered inoperable do to there updates.
you can go here to contact magellan support
Jul 19, 2009 | Magellan Maestro 4250 GPS
Our Magellan Maestro 4250, came on by itself and will not turn off.
is it plugged to AC charge when it comes on?
If not seek out the RESET hole and place a fine pin or paper clip end in and reset the unit
Jun 20, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
Map update error problem with Magellan 4250
I had the same problem until I plugged the usb cable into the back port of my computer. Then it worked. Something about using a higher speed usb port.
Oct 23, 2008 | Magellan Maestro 4040 GPS Receiver
Re: Magellan Maestro GPS 4250 original data erased....
download the new firmware again and run the setup
Aug 20, 2008 | GPS
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
Maestro 4250
Maestro 4250 is frozen. HELP ;-(
Dec 26, 2007 | Magellan Maestro 4040 GPS Receiver
GPS Logo
177 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Mike Cairns
Mike Cairns
Are you a Magellan GPS Expert? Answer questions, earn points and help others
