Question about HP Office Equipment & Supplies
Ink Jet refilling
I want to refill my Ink Jet Catridge.The printer is HP4335.
Please advice which color to be filled in which hole.
Thanks
GB
  • kkchelelgo Dec 20, 2008
    refilling of catridges
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
The refill kits tell you all about this.
Posted on Aug 20, 2008
Refilling procedure
You need to specify what brand is your printer.But the procedure is as simple as dirty. Make sure you have a cloth or paper to handle the messy part :).
Requirements: 1. Printer-Ink 2. Syringe with thin needle3. Piece of cloth
I will write how to refill HP cartridge, because I don't know your model.Ususally Hp cartridges have colored or black spot ont white sticker.Under this spot there is a tiny hole. This hole is designed to be used for refilling. You need to pierce the spot with the needle and start the refilling process.Make sure that there are no bubbles in the syringe and start filling slowly the cartridge. Do not hurry! Don't fill the cartridge to its full capacity. If your cartridge is 20ml fill only 15 or 16ml.After you finish set aside the cartridge for 30 minutes so that the ink settle. This is it!Good luck!
Dec 19, 2011 | Office Equipment & Supplies
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
I need to know how to refill my ink for my nx110 printer
The ink cartridges used in Epson's Stylus line of printers are very similar to the ones used in its other printers. A handful of cartridges--like the S020034, S020047 or S020049--may require a slightly different refilling technique, but they all basically entail opening a fill hole in the top to run down into the ink chamber within. Once the chamber is accessible, you can use a basic refill kit with a syringe bottle to refill the chamber, as with most printer-ink cartridges.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
1. Hold the cartridge upside down so the outlet holes to the printer paper are on top. Cover each hole with a piece of tape, then turn the cartridge right-side up.
2. Make a hole in the top of the cartridge above each ink chamber. For most cartridges, simply poke a hole through the label with a toothpick. With cartridges like the Epson Stylus 34 (the casing of which is black), pull back the label to reveal the filling holes and puncture the seal of each home. For the 47 or 49 color cartridge, drill a 1/8-inch hole in the shell between the label and front edge.
3. Determine which color of ink is in which chamber (if you're refilling a color cartridge). The toothpick used to puncture the hole should draw out some ink to show you. If you have a cartridge in which you punctured the label directly, the order of the color chambers is usually cyan, magenta and yellow. If you created the hole in another way (like with the 34, 47 or 49 cartridges), the order is usually magenta, cyan and yellow.
4.Fill the syringe bottle with 5ml of ink. Insert the needle in the filling hole and inject the ink. There may be a sponge inside the chamber, so make sure the needle goes all the way through to the bottom. The 34 cartridge takes up to 12ml of ink.
5. Tape over the fill holes you created. If you drilled the holes, plastic plugs (like the ones included in a refill kit) can work as well. Leave the tape on the outlet holes as you replace the cartridge in the Epson Stylus printer.
6.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Hp 6500 office jet refill
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
www.catherinecollege.net
Jul 21, 2009 | HP Officejet 6500 Wireless All-in-One...
Hp 920 xl ink cartridge filling instructions anyone have them
to refill 920:
Ink and printer
You'll need to either put it back in or replace it.
You need to have both color and black cartridges in for your printer to work.
Never throw away cartridges, save money and refill them or you can take them to most any computer store for recycling.
Mark
Apr 14, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Printer do not recognise color catrige
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 13, 2009 | Lexmark X1240 All-In-One InkJet Printer
How to refill hp 818 inkjet cartridge
on 818 hp cartridge five holes are there, which colour ink on which hole i have to put ink on them
Dec 03, 2008 | HP DeskJet F380 All-In-One Printer
Canon all in one printer refill ink cartridges
i have just filled my mx 310 with the jet tec refills as instructed....but do not insert the rubber bungs...instead put some celotape over the filling holes... then with a needle...pierce the celotape where the hole is( pin *****).... this set up is now able to breathe as originally designrd. Mine prints fine now this has been done (trial and error), but i might try better quality ink next fill. Its also wise to use glossy paper 230gsm or over for good results.
GOOD LUCK.
Dec 20, 2007 | Office Equipment & Supplies
Canon Bubble Jet iP1600
Hi meemee, If ink comes out of the ink nozzles on the cartridge then you probably just need to reset the printer page counter. Each time the cartridge is removed from the printer an empty cartridge message appears and a blinking amber light will display on the printer. Hold the paper feed button down for 3-5 seconds, and that should override the counter. If ink isn?t coming out of the ink nozzles then you may have an air pocket preventing the flow of ink. Try running your printer cleaning cycle a couple of times to see if that helps. Lastly you might try letting the cartridge site for 24 hours to let gravity try to fix it. As a last resort you can try unplugging your refill hole in the cartridge. If your cartridge ink is going to flow it will now, just be ready to re-plug the fill hole. Let us know how it goes and don?t forget to rate the post.
Jan 03, 2007 | HP DeskJet 3325 InkJet Printer
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
