KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
Posted on Jun 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kp2671 mixer- I see some oil residue around the base after prolonged use. I held the mixer upside down and on its side to find the model # and oil came out of the "planetary housing" that holds the beaters. Is this normal? Photos show only grease in there. Thanks! Bruce
Slo Mover
Level 2:
Novelist:
  • KitchenAid Expert 185 Answers
  • Posted on Sep 11, 2012
Slo Mover
KitchenAid Expert
Level 2:
Novelist:
Answers
185
Questions
Helped
126514
Points
281
So you finally bit the bullet and bought a Kitchenaid Stand Mixer, and man is it great. You have been using it for a month and made everything from butter cookies to bread. Now what?
I don't mean to be a "Kill Joy" but just about half the large stand mixers out there go unused for months at a time. Some of them only get used for the holidays and some don't get used for a year or two.
That's the problem.
The gear grease inside your mixer is a food grade vegetable based lubricant not a petroleum based Lube, that way if it drips out on your food no one is going to get sick. And, if you only get a drop or two in your food the recipe won't even taste different. BUT!!! You bought a Kitchenaid and they are supposed to last for years. well yes they will and so will the gear grease ... if you use your mixer regularly.
If you don't here's what happens. The gear grease because it is vegetable based breaks down with lack of use. the liquid actually separates from the solids and leaks out for two reasons. The first, liquids will find a way to get into anything even past a gasket. The second because the gasket has been torqued down by the motor hear and screws the gasket over time compresses and nobody ever goes in and tightens the head screws down again. the liquid now has a way to run out.
So what to do??
Well first a no cost trick. Get a towel from the bathroom, fold it a couple times and turn your mixer upside down on the towel. You will have to hold it as it will fall over if you let it go. Get some one to plug the mixer inand turn it on to speed 2, let it run for a little while and then start moving through the speeds at about 30 seconds for each speed. Takes about 2 minutes to do. Then shut off the mixer and then unplug it just to be safe because you are going to turn it right side up and there is no reason to get caught up in the cord and dropping the mixer so unplugg it every time. Now that the mixer is right side up again plug it back in and do it again going through all the gears for about 30 seconds. Repeat the process at least 3 times. the last time you do it let the high gears or speeds go a little longer and especially when the unit is upside down. Trying to get the gear grease a little hot.
Why all the shinnanagans?? Well simply you are remixing the grease in your mixer. Yep! that's one nice thing about vegetable grease, is that you can remix it and it will be good as new and last for a couple more years. That's the positive. Whats the negatives? Well if you haven't used your mixer in a few years then your grease may be to separated and the liquids have run out along any path way in the mixer and no where near the grease solids that now look like black celery pulp. If you have used your mixer a couple times during the non use times as the liquids separate the mixer will now get a little warm from it's occasional use and the liquids will evaporate. remember that this is vegetable based grease so the liquids are water not petroleum. Now you are left with a gooey sticky mess everywhere in your mixer. That take about half a day to clean along with about 2 rolls of paper towels and a box of "Q Tips" and a couple skinned knuckles. Then you will need to acquire the proper grease to re-pack your unit and a new gasket.
If you are not inclined to do it yourself then you need an after warranty technician to do it or send it to a factory authorized service center. If you use factory authorized you need to spend from $90.00 to $125.00 plus one way shipping.
The moral is if you are not going to use your mixer for extended periods of time the at least twice a year pull it out and mix the grease by the above mentioned method. It really really works.
if after the mixing process you still have leaks or you see a dirty edge running around you trim ring or band then you probably need to re-pack the insides.
Oh!! you really have to clean everything inside too. Why?? because if you have poor grease, then you may have been grinding gears and you may have metal shavings floating around and if you just re-pack then you still have metal shavings which are not good for the insides of you mixer.
USE YOUR MIXER!!!!!
Anonymous
Level 2:
Novelist:
  • Expert 153 Answers
  • Posted on Jul 03, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
153
Questions
0
Helped
71145
Points
327
There are only two places where Food Grade Grease is used: In the
Transmission Housing (normally installed with a gasket) and in the Planetary
Assembly (Agitator gear). Over times, the grease will get hot and turn into liquid.
The Beater shaft has an O-ring to prevent oil from leaking down, but there is
nothing to prevent oil from the Planetary from making its way down your mix.
Depending which model you have, it's time to open up your mixer, clean out
all the oil and replace it with fresh Kitchenaid Food Grade Grease.
How do I replace the speed control lever on a kitchenAid artisan mixer
Remove back cap, remove white wire and black wire from lower corner of speed control plate, both on same side on adjacent terminals. Remove the gasket thing at the back as well.
Remove chrome drip ring from around planetary, knock pin out of planetary and remove the planetary.
Flip upside down on a towel and remove pedestal by taking out hinge pin (1 locking screw from underneath inside pedestal)
Remove all screws from bottom side of gearcase, 5 around planetaty, 2 in the middle and 2 at the back.
You can now seaparate the gearcases to get to the speed control lever which is held on by 1 screw.
7answers
How doI fix mixer that leaks oil out beater holes
There ate two ways to fix this problem, but first there is the matter of understanding what is leaking. The oil you see leaking is actually a food safe vegetable based gear grease. The grease separates during heavy use (years of service) or when the mixer has not been used for an extended period of time. (months or years) The recommended way to fix the problem is to do a full tear down then clean then add new grease and a new gasket, cost (By Kitchenaid at a KA service center) around $140.00 US + or -, It involves shipping and around ten days in time. The second way is kinda simple and does not cost anything. Get a towel, thick and soft to protect your finish, get your wife or husband, get an extension cord, spread the towel out on an open counter top, plug the extension cord into the outlet, turn the mixer upside down on the towel, have your significant other hold the mixer by the base while you plug the mixer cord into the extension cord, turn on the mixer no more than 2 or the second click on the speed control switch / lever, hold the mixer upside down like this while the mixer is running and keep it running for at least three (3) minutes, turn the mixer off and turn it right side up and turn on again for two minutes, then do it again two or three more times, upside down for a couple minutes then back right side up and so on and so on, after about 15 minutes stop. put everything away, you are done. What you have effectively done is re-mix the grease and it should be good for another couple of years. When it starts to leak again re-mix again. Or send it to KA for the rare and unique opportunity to spend a hundred bucks that you don't' want. hope this helps. By the way if you get some drops in your mix it will not hurt anybody. But you do not want to eat a great deal of it or you will require the use of a laxative afterwards.
Oil in mixing bowl during operation from motor head
there is 6 oz of a food safe lubricant in the motor housing that is held in by a gasket around the front of the gear housing in the top of the mixer, the gasket is leaking the separated liquid of the grease. The grease because it is a vegetable based product separates over periods of non use and the gasket gets soaked and releases the liquid into parts of your mixer and it drips it's way out when you use it. the best thing to do is install a new gasket and remove the old grease then repack and add a new gasket. There wasn't that easy?? problem is that most people don't know where to buy the KA approved grease and gasket (ebay about 17.00) and most people don't know how to take their mixer apart to do this, (youtube has about four really good step by step videos on how to do it) BUT!!!! there is a trick that often works, seriously!!! get a towel and spread it on an open work space, grab your significant other or any one that will tolerate you when you get this way you will need their hand. Now turn the mixer upside down (no I'm not being sarcastic) turn it upside down, now have your partner hold it while you reach down and plug it in and turn it to speed Two, and hold the mixer like that for two minutes, (that's why it's better to have a really good friend help you they won't tell you how nuts you are doing this, but!! continue. After two minutes turn the mixer off and turn it right side up and turn it on again for two minutes, then do it all over again upside down then right side up, do this at least three times. the drip is now fixed. You think I'm nutz right??? Wrong!!! What you have done is re-mix the gear grease, the liquids are now re-mixed with the solids or gear grease base material. It should last about a year or so. My suggestion is to do this once or twice a year if you are not going to use the mixer for long periods of time. The separation usually happens when the mixer goes for long periods of time without use. the grease is designed to work for five or ten years without being replaced. however the gasket is made of fiber and the weight of the motor head pressing down on it for a few years of say 17 pounds causes it to compress and allow the liquids to leak out. So to fix that you take of the drip ring off (round silver thing that attaches to the planetary ) then drive out the little silver pin in the planetary shaft and pry off the planetary. you will then see five flat head screws that hold the motor head to the lower gear case, thightem them up and re-assemble the mixer then remix the grease, you have fixed your drip problem without spending a dime and it will stay fixed for years as long as you have no other issues arise during it's life. Hope that helps you.
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
There is oil leaking into the bowl from the head, right where the beater attaches. I noticed it when the whole area was dripping with brown liquid. Can I fix this myself?
Yes you can. Here's the link to an exploded diagram, and parts list.
You'll need to disassemble the mixer down to the bad part, order and replace the defective piece and reinstall it. I always recommend getting the exploded diagram first as it makes the process much easier, especially for the first time.
http://www.ereplacementparts.com/kitchenaid-kp2671-stand-mixer-parts-c-114958_114959_116129.html
Best regards, --W/D--
Please feel free to rate this solution! Thanks!
2helpful
The handle will not allow me to raise the bowl to make contact
Looking at the following parts diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
You can see the linkage on page 6. Turning the crank handle #22 counter clockwise rotates the link #18, which is attached, which pulls on the rod #11. There is a spring clip #10 on the rod which sometimes comes off making the linkage bind. Make sure it is in place by turning the mixer on its side and looking up inside the base.
If it is in place then spray a small amount of lubricant on the linkage to lubricate all of the moving parts.
Also put a small amount of lubricant on the sliding member #7 where it slides against the stand section #15.
Note: Don't try to move the crank lever when the mixer is on its side since it will bind. It requires gravity to pull the sliding part down, and with it on its side the sliding part will not move downward thus binding up the linkage.
1helpful
The attachment jams
See pg. 12 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707946.pdf
There is a screw in the base of the mixer which is turned
clockwise to raise the bowl
and counterclockwise to lower
the bowl.
Oil leaked from Kenmore mixer- model mumber 201
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Leaking oil at the base
A TV show "How it is made" was in the Kitchen Aid factory and they used a thick grease and no oil in the mixer. Does your unit get hot? Maybe its melting the grease (dark brown)..
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
