Question about Sony Ericsson K550i Cellular Phone
External speaker have
My phone have very low volumed external speaker. is this a major problem or else?
  • Anonymous Aug 25, 2008
    same
  • 33 Answers
Thats not a major problem. Try adjusting the equalizers. here is the user guide. volume control can be found in page 22
Posted on Aug 20, 2008
My phone only works on speaker, even when it have a volume level of seven, it won't work on a regular phone call. Also any icons that use to beep no longer have any sound
Notifications sounds from either external speaker or headphones, but never from the ear piece volume. Your question suggest that the external speaker is damage but it only works on external speaker. Try using a headphone or a bluetooth to make calls, if they work, then you need to fix the external speaker.
Jun 26, 2017 | Computers & Internet
External speakers won't work on HP T5570e Thin Client
Try to use earphones, plug them in to phone audio connector....
try if it works..... if so, disconnect them and plug speakers.... and try again.... if doesn't work, go to audio advanced setup and check if speakers are not muted, or set up voicevolume level is too low. Play with that setup....
Also some computers can turn on or off speakers in Bios.
If problem will not be solved, try to use USB speakers
Jan 13, 2014 | HP T5740 Thin Client Desktop PC
My phone have low volume
Please check using an handsfree or an external headphone. If the volume is good then the fault is with the speaker of the phone. If not the output of the amp in the phone is low and can be a problem in the mainboard which might require help as a good soldering station is needed to replace the IC.
Jul 14, 2011 | Nokia E66 Smartphone
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
Plug in external speakers w/ volume very low in HP2009m screen
check if the external speakers u plugged in came with an internal amplifier, if not then u will have to use an external amplifier to get max output from your external speakers.
Sep 02, 2009 | Audio Players & Recorders
Env2 vx9100 call volume soft
We have 3 ENV2's in our family. None of them have volume problem. The speaker phone is especially loud when used in indoor environment. It is so loud that I have to turn the volume way down when used with good quality ear set. You probably are right about the phone being defective.
Aug 23, 2009 | Verizon Communications enV2 Cellular Phone
Increase external speaker volume
when the speaker phone is on, try pushing the up arrow, unless you have the button on the side, But I think it is the up arrow while talking.
Also go into regular menu settings, go to sound settings, speaker volume and headset volumes should both be turned all the way up.
May 30, 2009 | Nokia 2600
Low volume on external speakers, no volume on internal
I have all the audio drivers for that model. Please let me know what operating system you are using. These are large files, around 7mb for xp.
Mar 07, 2009 | MPC Computers ClientPro 414 All-In-One PC...
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Volume
Buy some external speakers and use those
Sep 07, 2007 | Audio Players & Recorders
Sony Ericsson K550i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
