I AM TRYING TO INSTAL MICROSOFT WMF 11 REDIST FOR MTP SUPPORT IAM GETTING A MESSAGE SAYING THE NTVDM CPU HAS ENCOUNTERED AN ILLIGAL INSTRUCTION. CS:07131P:OICSOP:6368617273 AT C:DOCUME~1\terry\APPLIC~1\SONYSE~1\langpack.exe
  • Anonymous Aug 27, 2008
    i'm to install the microsoft wmf 11 redist for mtp sypport but i keep getting "requirements not met" when i click install
  • big_ste Aug 31, 2008
    I have the exact same problem for my sonyericsson w350i.
I AM TRYING TO INSTAL MICROSOFT WMF 11 REDIST FOR MTP SUPPORT I AM GETTING A MESSAGE SAYING that "You are not meeting the requirements".
What to do ?
Posted on Aug 21, 2008
Upgrade you windows media player :P to latest version - this should help for requirements :)
Posted on Sep 21, 2008
Im getting that message also.
Posted on Sep 20, 2008
The ntvdm cpu has endountered an illegal instruction. Cs:0df1 IPL01f6 OP: ff ff 00 00 ff
SYMPTOMS
When you attempt to run a 16-bit program on a computer running Microsoft Windows NT 4.0 Service Pack 3, the program may quit immediately, or you may receive the following error message:
Hidden Console of WOW VDM
The NTVDM CPU has encountered an illegal instruction.
CS: 04c3 IP:3937 OP:c71c 9d 37 00
Choose Close to terminate the application.
When you click Close, you may receive several similar error messages.
CAUSE
This behavior can occur if you use an incorrect version of the Command.com file. For example, this issue is known to occur if you use a Command.com file included in Microsoft Windows 95, dated 7/11/95.
RESOLUTION
To resolve this issue, replace the Command.com file in the Winnt\System32 folder with the same file from another computer that is running Windows NT Workstation 4.0 or Windows NT Server 4.0, and then make sure that there are no Command.com files dated 7/11/95 on the computer. You can also replace the Command.com file on the computer with the same file on the Windows NT installation CD-ROM.
PROPERTIES
Article ID: 245184 - Last Review: November 1, 2006 - Revision: 1.1
APPLIES TO
Microsoft Windows NT Server 4.0 Standard Edition
Microsoft Windows NT Workstation 4.0 Developer Edition
Jul 22, 2014 | Dell Computers & Internet
What is microsoft wmf 11 redist for mtp support and how do I get it?
Hi, i think its Microsoft wmp 11 redist, anyway upgrade your window media player to 11 and download the latest directx 9c you can download them from Hippo website Directx and Wmp11.
Hope that helps...
Cheers
Apr 27, 2009 | Computers & Internet
The ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Sony ericsson phone
Go to microsoft's website you can probably find it there
www.microsoft.com
Oct 27, 2008 | Microsoft Windows XP Professional With...
Sonyericson 350i
if yuo are with Windows XP you should have Windows Media Player 11 or more to avoid this issue with Microsoft Wmf 11 Redist support.
This issue does not appear with Vista.
D.Gyoshev
Bulgaria
Sep 10, 2008 | Computers & Internet
VISTA:The NTVDM CPU has encountered an illegal instruction
The link below is a step-by-step troubleshooter from the Microsoft website. You'll just need to follow all the instructions on the site and you should be able to fix it all by yourself. This seems to be a common error with windows.
Troubleshooting NTVDM and WOW Startup Errors
Computers & Internet Logo
913 people viewed this question
David Payne
David Payne
