Question about HP LaserJet 2200dn Printer
Can't print at all
Loud noise from the roller, now can't print at all, which 3 light flashing at the same time.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Sounds like your machine is truly unhappy. time for a service call from a factory person, sorry to report.
Posted on Aug 20, 2008
Why is ricoh 6330n making a loud noise while it is printing?
Check the transfer roller (the sponge roller) there will be a gear on that roller. Lubricate is with some spray on lube.
Aug 11, 2014 | Ricoh SP 6330N AllInOne Laser Printer
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
Printer HL-3070CW - LOUD Grinding noise when it seems to be running large print offs. It is almost like it gets too hot
My 3070CW makes the same noise. It is caused by the transfer belt. One roller is driven by a cog and this goes fine. The other roller has a tensioner and this roller is making all the noise. While the noise is really loud and annoying - it is completely harmless. Hope this helps.
Aug 09, 2011 | Brother HL 5250DN Laser Printer
When I am printing, there is a loud noise. Like something is not rotating correctly. Everything prints good, but that noise is really loud. It seems to happen when it feeds paper.
Hello there,
If there is a loud and buzzing noise inside it, the encoder strip, or the one that guides teh cartridge must be dirty. this causes buzzing sounds and mis alignment.
another is the rollers having too much paper residue in it.
i would recommend for you to clean the rollers with a lint free cloth and some water (just to dampen it)
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 16, 2011 | HP DeskJet F4280 All In One Printer InkJet
Why doesn't paper feed after "print" instruction? Printer merely makes a mechanical noise and states "paper out" condition.
Hello.
There are lots of reasons why this would happen:
Foreign object (could be very tiny)
Any power lights flashing ?
Paper feed rollers may need cleaning - try (from Canon Support):
1. Ensure that the printer is turned on. If any paper is loaded in the printer, remove it.
2. Select which roller to clean, the auto sheet feeder's or cassette's, by pressing the <Paper Feed> switch on the printer.
3. Hold down the <Resume/Cancel> button; when the Power lamp flashes green three times, release the button. The paper feed roller will rotate as it cleans itself.
4.. Repeat step 3 twice.
5. Load three or more of A4 or letter sized plain paper in the auto sheet feeder or cassette, as selected in step 2.
6. Repeat step 3. The paper that is loaded in the printer will be fed through the printer and ejected.
7. If printing problems persist, repeat step 6 up to three times.
Could be a hardware error and the printer would need servicing - still under warranty ?? If so, return to Canon for repair or replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Hi, I have a NordicTrack Treadmill, A2050. When the unit is turned on, it has become very loud. The faster it goes the louder it gets. At higher speeds it sounds like it is going to explode. Any...
Unplug unit then remove motor shroud then plug unit in then start treadmill your going to use a flat tip screw driver as a stethoscope. Now place the flat on the motor at edge close to the flywheel put your on the handle your ear and you should be able hear if the loud noise form the bearing if not, then repeat procedure on the other end by the fan if the noise is pin pointed on the motor then replace motor, if not originating from the motor the proceed to the front roller.
Use a flash light and observe and locate the font roller shaft so that you can comfortably rest the tip without it slipping on either end of roller.
As before repeat the procedure that was performed on the motor if noise originated their then replace roller if not proceed to rear roller.
Use you flash light and look the adjusting bolts where the end caps are the proceed to insert the screw driver and make contact with the tension bolts listen to each side.
You should locate noise with this procedure take your time and be careful
May 16, 2010 | Nordic Track NordicTrack Treadmill, A2550
Tried to feed envelope. Jammed. Printed two regular sheets that day after jam. Now, next time I turn on. Makes loud noise during warmup when rollers usually test their rolling. Same noise when I send print...
Beside you is broken drive seizing roller, here fault of the **** of the grapping or gear or electro relay. Persuasively - a repair for service this typical fault. Thank you
Sep 28, 2009 | Samsung ML 2010 Laser Printer
Printer is not working.
There are several things in the front that could be making that noise.The transfer roller,paper guide/top ublique roller and front obligue roller which is on the left side front. It is hard to say. I guess the printer is printing OK. If not what is the printer doing? Do you get any paper jams? Printing light? Can you rub the print off the paper? Any labels stuck? Please answer questions so I can help you. My guess is a roller problem. Which one is hard to say since I can't hear the printer myself.
Jan 13, 2008 | HP LaserJet 4L Printer
HP LaserJet 2200dn Printer Logo
114 people viewed this question
Seeker5211
Seeker5211
