Set one of them up in bridging mode.
To get to the admin screen, check the bottom of the voip box to see if it's accessed through another IP.
If you have the voip router plugged into the Netcomm router, the IP address to access the voip is going to be assigned by your netcom. Assuming the voip router isn't serving dhcp addresses (i.e. 192.168.1.100, 192.168.101 and so on)
FYI: Be sure you don't have both routers set up as dhcp servers.
You can acquire the voip router's ip from the admin interface of your netcom router.
If you are wanting to get them to talk to each other through entirely different IP addresses (subnets), create a route in your netcom router for your voip router. Bridging mode may make things easier for you.
Going back: If you have your netcom dishing out ip addresses to wireless and cable users, and you plug in the voip router to the netcom router, your voip router will receive an ip like any other computer on the network. Thus will use the netcoms ip as the default gateway and it gets messy after that --lack of connectivity.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/nicole_525c14680d45ee5d
SOURCE: VoIP router blocking internet access
you can go to port forward.com and it will do it for you, just click on 'start here' but if you wish to do it yourself the ports that need to be open are- 1024-1030,5060-5065,10000-20000 http://www.portforward.com/
SOURCE: voip and speedstream 6520
I have the same problem
Contact me at [email protected] if anyone solves it
SOURCE: Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses? it's probably PPPOE; make certain that your belkin router is set to the correct protocol. if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
SOURCE: D-Link DIR-625 Wireless Router is Blocking Web Address
Hi jshaw51
HERE's D-Links listing for your router.
HERE's where you can find downloads, etc. for the router. (including an owner's manual) You'll need to choose your router's version then you'll be directed to the appropriate page.
(01) Can you access this web site from any of the other computers on your LAN (when this router is connected)?
(02) Have you ever been able to navigate to this web site from the computer you're referring to while this particular router is connected?
(03) Have you recently installed any other networking equipment or a software firewall on one or more of your LAN computers?
(04) Were you able to ping the LAN computers prior to the onset of this problem?
(05) Can the LAN computers ping your computer? If not, were they able to previously?
(06) Has anything occurred or any changes been made that precipitated or coincided w/ the onset of this problem?
(07) Do you have any other information regarding this issue?
(08) If you like, you can **first** backup your router's configuration and **second** reset it to factory defaults and see if the problem persists.
(09) You can readily restore the backup. This will just be a quick way to determine if the problem is w/ the router configuration (assuming you were able to navigate to the site in question when you 1st got your router.)
Please, post back here w/ answers to these questions along w/ any observations or questions you might have.
We'll continue to work w/ you until the problem is resloved.
Please, hold off on assigning ratings to any of the experts' contributions until you're all set and have no more questions for us. (Once you assign ratings, the problem will be automatically closed and we'll no longer be able to assist you.)
Thank you,
BJ @:)
SOURCE: have belkin wireless/modem router, was
Try using a dynamic ip address. I think you only use the static if having problems. Just read this.
A dynamic IP address is assigned to a customer’s modem or router,
generally via a remote server (such as our own UWClub server). This
provides the user with an IP address from an available pool of
addresses every time a connection is made. This is the most common type
of IP address for our broadband/Broadcall customers.
Thats off The Utility Warehouse page.
We need much more information first. =-]
How is it set up?
What are all of the IP's?
Why use two routers?
