Question about Whirlpool GB9SHDXPS Stainless Steel Bottom Freezer Refrigerator
Warm fridge, cold(er) reeezer
Figure this is a defrost timer issue...any suggestions as how to test? Thanks!
  • Anonymous Mar 18, 2009
    I just had mine checked and it is the defrost control that went out. Needs to be replaced
    President:
  • 1,197 Answers
We ll see how u need to check the defrost timer....
Before testing the defrost timer, unplug the freezer to avoid an electrical shock hazard.
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, shuts off power to the cooling system and sends power to the defrost heater. In newer models the timer advances only when the compressor or defrost cycle is running - an improvement for efficiency. As the timer advances, power to the heating element shuts off and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Test the timer for continuity using a multitester. Set the multitester to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the common wire in the connector plug; it is usually the white wire.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multitester should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it is likely that it should be replaced.
Posted on Aug 30, 2010
My roper refrigerator freezer ices up and the fridge is not cold. Model RT14BKXKQ05
You have a defrost problem, could be the timer not advancing, bad thermostat for the defrost system or an open heater. All of these items will cause this issue you have. the only way to find out is to test all the items. If I have to guess, I would replace the thermostat first, but its a guess as I am unable to test them. Good Luck
Mar 31, 2016 | Roper Refrigerators
GE refrigerator model GTS18DC. Freezer is as cold as it should be. The refrigerator isn't getting cold. What could this be? Thanks!
freezer blows cold air to fridge, sometimes freezer freezes at back and blocks holes for outlet to fridge, defrost and restart, or take back panel off freezer and chip clear
Apr 13, 2015 | GE Refrigerators
Warm fridge cold freezer
This usually happens when your Defrost (heater) is not working, Firstly Get your Defrost Timer Checked. If that is the problem then the timer is much easier to be replaced. Depending on the models the Timer prices differ from $10 to $115.
If this is not the issue then Inside the freezer is the Defrost Heater Placed, and you will figure out that this unit is having the problem due to which the channels to pass the Cool air into the Fridge is blocked and not keeping it cool. You will have to check if this Heater can be fixed or replaced. *Again this cost will Differ based on the models*
Mar 18, 2014 | Refrigerators
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Refrigerator side warm is there a fan on that side
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 27, 2011 | Refrigerators
Top shelves of fridge and freezer warm. Bottom shelves all cold.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 05, 2011 | GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB...
My freezer gets cold but fridge stays warm i have defrosted and the problem continues kenmore model# 9704284 any suggestions
heatman101
Oct 24, 2010 | Kenmore Refrigerators
Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
May 12, 2010 | Electrolux ER7626B Bottom Freezer...
Whirlpool GB9SHDXPS Stainless Steel Bottom Freezer Refrigerator Logo
308 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
