Question about HP OfficeJet 7310 All-In-One InkJet Printer
Trouble scanning or faxing
My all in one will still print fine,  but when I go to fax a document,  or scan a document,  it will begin the process and then a loud noise,  like a slipping gear RRREEEEEEE  and the process stops halfway,  error lights flashing.   Heard of this?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Yeppers..that's the mechanism under the glass..sounds like either it's stuck or the belt is going bad..service level issue, I'm afraid.
Posted on Aug 20, 2008
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
Panasonic KX-FLB758 is not copying documents properly. Any idea why? If I scan and then print, it is fine but not when I try to copy.
Call 1800-211-7262 for Panasonic's capable Technical Support; be sure to have the serial number of the product ready.
Jun 05, 2012 | Panasonic KX-FLB756 Plain Paper Laser Fax
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Black streaks on prints
Where the original page that you wish scanned/faxed there will be a device called a "scan part". This device "reads" the paper to be faxed/scanned as it passes. It usually is found very near where the paper to be faxed goes in.
If there is a spec of debris on this part it will cause a fine line straight down the document. If its dirty, the document will be too! Just give it a good cleaning and you should be fine.
Did this help? Click "FixYa" below!
Thanks
Len
May 29, 2009 | Brother IntelliFAX 4100 Laser Fax
Can't scan on the HP OfficejetJ4580
Uninstall everything that has to do with your old HP printer, drivers, photo processing, etc. Reinstall software with J4580 printer. That should open HP Digital Imaging Monitor where you can set scanning options. Plug printer into the back opf your computer. Plug power supply directly into the wall socket.
Nov 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
When scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Nov 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Canon Fax B160 sending fax troubles
The fax transmission speed was set to 14400, we have solved the problem by putting down transmission speed to 4800 and now emission works without troubles.
Mar 03, 2008 | Canon FAX-B160 Plain Paper Bubblejet
HP OfficeJet 7310 All-In-One InkJet Printer Logo
110 people viewed this question
Ben Johnson
