Question about Maytag Dryers
It makes a concent noise when running. it o most sounds like something is lose between the inner lining and outer casing of the dryer itself. The place where the cloth's sit in. It still works but noise is getting louder last 3 weeks. Please help. thx Joe
    Genius:
  • 2,920 Answers
The belt is worn out it needs to be replaced
Posted on Aug 20, 2008
My Samsung wash and dryer model WD0704REU makes a noise when spinning the clothes. normally it's quite but now make a sound. it gets louder with speed increases. please help,
I suspect that you either have a Tub bearing problem; there might be a fault with the inner tub (it has come loose on its mountings). or the counterbalance weights on the outer tub may have worked loose.
But from the limited information you have given, I tend to think that the inner tub bearings may be failing?
I hope this helps?
Sep 27, 2016 | Samsung Washing Machines
Sound when it spins that sounds litle bearings
Check for something caught in the inner bowl. Check with torch if something caught between inner & outer bowl. Check main bearing, main bearing noise is usally associate with leaking water.
Dec 19, 2013 | Haier HLP21E Top Load Washer
When the dryer is running it makes squeaking noises. what is the problem. what can be done to fix it.
There could be something stuck between the inner and outer drums, or (more likely) the main drum bearing has worn out. A third possibility is that one of the motor or idler pulleys is making the noise, but in my experience this isn't extremely likely. The best approach would be to remove the rear panel (don't forget to unplug first) and turn a few things by hand to see if you can identify where the noise is coming from. Remove the back panel of the drum to clear anything stuck between the inner and the outer. If you find that the drum bearing is worn, you should be able to undo the bracket holding it and purchase a replacement from an engineering supplies store or specialised bearing retailer.
Jun 27, 2011 | Dryers
Whinning noise in the primary chain case. I alreadt replace the tensioner shoe
With the engine running, put the transmission into gear and sit there with the clutch lever pulled in. Do you still hear the noise. If so, most likely the noise is in the primary itself rather than the transmission. Since you didn't specify whether the bike is a Sportster or a BIg Twin, it's difficult to say what the noise may be. It could be a bearing going bad. The problem with that is that you can disassemble the bike and never find the bearing. It could be the big bearing in the outer clutch shell or it could the mainshaft support bearing in the inner primary if it's a big twin. A Sportster has basically the same bearings but in different areas. If the bike is equipped with one of those automatic primary chain tensioners, I've seen them make a noise as well. Then again, a noise like that is very difficult to find. It seems to travel all through the engine. It could possibly be an inner cam bearing going bad. They sound exactly like the alternator whine on a Chevrolet. If you have one of those mechanic's stethoscopes or long screwdriver, listen to various places on your engine to try to locate the noise more closely.
Good Luck
steve
Apr 03, 2011 | Harley Davidson FXDX Dyna Super Glide...
Electric Dryer Model DCSR473EVOWW has loud scraping sound when drum turning .... sounds like metal on metal
There is likely to be something stuck between the inner drum and the outer casing. In my experience this is most commonly the wire from an underwired bra! (belonging to my wife!)
If the inner drum has holes in it feel the surface carefully all over to try to detect a wire or other object protruding into the drum. If you find something it can often be pulled free with a pair of pliers or pincers.
Jan 04, 2011 | GE Dryers
On the spin cycle the machine is making a lot of noise. Could something be lose on worn to cause this. We have tried to stop the machine and reposition the load, but it did not help. The machine is just...
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.If the bearing is getting out of its way then its faulty weak motor causing this.Check out both the bearing and the motor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 31, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Have a front loading washing machine, it is making a horrible noise when it turns
Either something has gotten between the inner and outer drums or the inner drum support bearing has gone bad. Almost complete tear-down to fix it. Lift up and down on the inner drum (when machine is off) to see if it seems somewhat loose and makes a clunking sound when you do so. If it does, that indicates a failed shaft bearing.
Aug 06, 2009 | Da-Lite Standard Fast-Fold® Projector...
Kenmore dryer keeps making a ringing sound when dryer is on.
If the nois is kind of rattling noise, then it is usually caused by objects (coins etc.) trapped between inner and outer drum. If instead is an high pitched noise that gets louder when the machine spins faster, then it is usually a bad drum bearing.
Jul 14, 2009 | Kenmore Dryers
CLUNKING NOISE - SOMETHING TRAPPED BETWEEN INNER & OUTER DRUMS?
Yes, there is something trapped between the inner and outer drum, you could try removing the sump hose from the bottom of the drum, this will give you more room to fish about than possibly removing the heater. If you do remove the heater, you may not get it back in, then you will have to fit a new one.
The sump hose is the large hose fastened to the bottom of the outer tub.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Noise problem
the problem could be either of two bearings. It could be the tub bearing which would require the removal of the inner and outer tubs. it could also be the bearing on the top of the brake package. in either case you will need a specia spanner wrench to remove said parts ( naturally its a different wrench for each) my advice is to call a service tech and let him make a recomendation
Jun 19, 2007 | Maytag MAT13MN Top Load Washer
Dryers Logo
50 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
