Question about Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 9300-3655: Shuts Downs When Idle
I have had this laptop for about a year and I pretty much leave it on 24 hours per day. Lately, overnight or during the day while I am at work (and the laptop is home), it has begun to shut itself off. It appears to be doing an "orderly" shut down because it never runs checkdisk at startup, but I could be wrong.
The laptop remains plugged in most of the time, which I am sure is not best for the battery; I believe it does need a new battery because it doesn't last very long anymore.
Within the Acer ePower Management, it is set to "Maximum Performance." I did change the settings for "System Standby" and "System Hibernation" to "Never," but it still shuts down.
Many times I leave work or web pages open so that I can pick up where I left off, so this has become a bit frustrating. If anyone can advise me on getting it to stay on again, I would greatly appreciate it.
I have similar problem to the one in this link:
http://www.fixya.com/support/t444675-acer_aspire_9300_3655_shuts_downs_when
The different is, it runs checkdisk at startup. So this mean the system was not shut down properly.
Last month, it shut down if I left it idle for more than 2 hours. Now, only 30 minutes.
Anyone know why this is happening and how to fix it? Thanks.
Blow the dust out of your computer....it may fix the overheating problem.
Posted on Aug 22, 2008
Does it just shut down randomly? and then when you turn it back on it shuts down nearly straight away? if so then it sounds like the processor is overheating and as a saftey mechanism it shuts down. which could be a big problem.
or you just need a new battery. because you are supposed to only charge it when it is dead. if you keep it on charge and plug it into the mains randomly,then the battery will eventually lose it capacitence (basically how much charge it can hold) and then it wont last long atall. you want to hope its the battery.
hope this helps.
Posted on Aug 21, 2008
SOURCE:
I turn on my acer aspire laptop and it lights up for 1 second and then shuts down how can turn on my laptop
You can try using it with the power supply pluged in failing that I advise you go to your local computer shop and buy a new battery for it. Ensure you charge it for 24 hours before using it
Aug 04, 2012 | Acer Computers & Internet
Number of hours of charging for first time of using acer aspire laptop
Let it charge for a good 24 hours, you will get maxium capacity out of the battery.
Jul 16, 2012 | Acer Aspire 1710 Notebook
I have a Acer Aspire One with Linux system, fine for two years. After using it the other day i switched it back on the day after , it connects to the internet wirlessly ok but when I click on the icon to...
We ran a typical Acer Aspire one battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
Jan 20, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an Acer aspire 5050 and when i try to turn it on i hear the fans starting but nothing hapens on the screen. i tried to conect it to a pc monitor but it didn't work. I think there isn't any video...
hello gligor,
try this.
Turn Off Laptop
Remove the Power Adapter Pin
Remove the Battery and leave the Laptop Idle without Power n Battery for about 2-3 Hours
Fit the battery again and connect Power Adapter and try again
Feb 04, 2010 | Acer Aspire 5050-3242 Notebook
Aspire 5000 turns-on and after 5 sec it shuts down
Sounds like Hardware fault but I have found a number of laptops where they were infected, So ot be sure start the laptop in safe mode by pressing F8 every 4 sounds a couple of times select safe mode, did the laptop shutdown? Regards GeWiz
Jun 13, 2009 | Acer Aspire 5000 Notebook
My Acer Aspire 5100 wont start up correctly
Try removing the battery and connecting the AC adapter then see if it boots up.
Reinstall the battery and keep the AC adapter connected and see if it boots up, if so leave it charge the battery for several hours.
If none of these work, get a replacement as there is a more segnificant problem.
I hope this helps.
Good Luck.
Mar 14, 2009 | Acer Aspire 5100-5033 Notebook
How do I keep my computer on at all times? Also, how to work the built in web cam?
charge for 24 hours then leave plugged when working//you can get a bigger battery through acer.com
Apr 12, 2008 | Acer Aspire 5610-4648 Notebook
It sounds like you are getting a blue screen error.
Most of the time these are resolved by manually running CHKDSK /R
To check for a blue screen error, right click on "My Computer"
Go to properties, click on the "advanced" tab, Click on the "Startup and Recovery" settings button.
Under "System Failure" uncheck "Automatically Restart"
Now if your computer is restarting do to an error then you will see the blue screen.
The important information to give back is the 0x000000** part which is displayed.
Mar 14, 2008 | Acer Aspire 9300 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
170 people viewed this question
Ekse
Alun Cox
