Question about Tally Dot Matrix T2265C Printer
Please help my tally t2265 shows an error saying hardware alarm wrong board
    Problem Solver:
  • 17 Answers
On board replace IC5.
Posted on Jan 02, 2013
I am already faced this problem, This Problem is due to Bad Head cable. Repaced that cable, your Problem will be resolved
Posted on Nov 24, 2008
What is the problem when a Tally T2265+ printer show the error message? How to clear this error message?
it sounds as if this will be a problem with a board and you will need to have it replaced
Jun 20, 2014 | Tally Office Equipment & Supplies
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
Our tally 2280 Dot matrix has an alarm code 025609413032 What causes this to be displayed on the 2280 screen.?
check out this FAQ page for the hardware alarm codes:
http://support.dascomeurope.com/index.php?option=com_content&view=article&id=295%3Ahardware-alarms&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
Mar 19, 2010 | TallyGenicom 2280 Matrix Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
I have a tally t2265. when i switch it on it comes up with "hardware error". Please help Don
9 out of 10 times this error is caused by the print head assembly binding up on the platen (the metal bar that the print head moves back and forth on). Remove the ribbon and paper from the printer. Wrap a thin cloth or Kimwipe around the platen and spay some WD-40 on the cloth. Work the cloth back and forth on the platen to clean it. Then with the platen still damp with WD-40 work the print head assembly from side to side, this will clean out the inside of the print head assembly. Clean the platen one more time.
I have seen this problem caused by two other things, a defective ribbon casette or worn out drive gears.
Dec 01, 2008 | TallyGenicom (048959) for T2265, T2280,...
Tally sprint pro
Please tell me the hardware alarm number . The number will display onthe control pannel LCD of your printer. Then only I can help you.
Aug 26, 2008 | Tally Matrix T2280 Printer
Tally t2155 - Showing "Hardware alarm wrong board"
change the logic board. your problem will solve.
Jul 29, 2008 | Tally Serial Matrix T2155 Printer
Printhead hot error on tally t2265 but all pins fire ok, just stops and gives error, printhead is cool to touch, after a few minutes it prints a line or two again. it does this immediately, not after a...
The problem is with the main board when it gets print head hot immediately. The power supply is still functional, but something on the main pcb portion causes it to give an immediate "Print Head Hot" alarm
Jul 22, 2008 | Office Equipment & Supplies
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Tally Dot Matrix T2265C Printer Logo
396 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
