Question about Canon Cameras
I have a canon slr 20D camera, I would like to restore the factory settings and don't seem to be getting high res photos what could the problem be?
  • dkwilliams Aug 20, 2008
    I have made a coment that my camera doesn't have the clear settings option in the menu bar?
    Thank you very much I have managed to solve the problem with your help (-:
  • Canon Master
  • 13,433 Answers
There is a small reset hole you can press to restore the settings, one moment.
Posted on Aug 20, 2008
  • Ekse Aug 20, 2008
    In the menu, you can clear all the settings
    Restoring the cameras defautlt settings
    1 select clear settings
    -press the menu button
    turn the dial to select clear settings then press set
    2 select clear all camera settings
    -turn the dial to select clear all camera settings then press set
    3. select ok then press set. the default settings will be restored.
  • Ekse Aug 20, 2008
    the reset process is covered in the manual
    http://gdlp01.c-wss.com/gds/0900000259/E...
    page 32
How do I factory reset my canon camera DS126061 EOS 20 D
In the menu look for 'Clear all Settings' and enable.
Mar 11, 2015 | Canon Cameras
Slr 20D canon camera
There should be a setting (usually in "image settings" or similar) to change the image quality between low, medium, high and RAW.
You probably want high.
Turn the wheel to the tool-icon (settings) and have a browse through the options. You'll find it without much fuss. =-]
Aug 20, 2008 | Cameras
Canon 20D slr
Take higher resolution pictures? hehe!
Go to the settings menu of your camera, then into the picture quality options and stick it on "high".
High-resolution images will take up more space, so make sure your memory card is large enough to hold the number of images you're going to take.
At 6 mega-pixel (the resolution) each image is going to be around 2-3Mb each. A 1Gb (1024Mb) card will obviously store around 500 pictures. =-]
20D slr canon
EOs 20D digital camera
Prior to models made in 2007 or later, no SLR camera (film or digital) was able to let you compose the picture before shooting it other than through the optical viewfinder. SLRs are different in this respect from compact digital cameras. You will only be able to review your pictures on the LCD after they are taken.
Jul 29, 2008 | Canon EOS-20D Digital Camera
The shutter continues to click in rapid concession the moment I replace the battery. I don´t see anny Factory Reset button on my Canon 20D? What to do?
Make sure the camera is OFF when placing the battery in it, and have the mode dial (Top left side) set to the green rectangle for automatic mode. Then turn ON.
Jul 09, 2008 | Canon EOS-20D Body only Digital Camera
Image quality
Hello there,
If you are correctly metering the exposure of your photos, and you suspect it may be the camera, try resetting the camera to its default settings using the menu. Clearing all the custom functions as well can sometimes help. I have seen some cameras get "stuck" into a weird shooting mode. Also, don't always trust your LCD. It is only there for reference, but is almost never a true representation of what you're going to get.
Hope this helps!
Apr 10, 2008 | Canon EOS-20D Digital Camera
Camera takes a few low resolution pictures even when the settings are for high res pictures
You should take your camera to service.
Normal cameras are meant to work above 0 deg C (32 deg F), but usually they work even at -15 C (5 F). When you work below the freeze point there may some anomalies, usually LCD turns blue or purple but photos look OK on a computer. Sometimes the camera refuses to take photos or shows bad focus, lens zoom mechanics get stuck etc. And you always experience significantly shorter battery life when in the cold.
It's a good idea to keep the camera in a warm bag and take it out before shooting. You can also keep it under your coat if you're not practicing a sport like skiing (because of body moisture).
Jan 15, 2008 | Canon PowerShot S3 IS Digital Camera
Canon EOS 20D SLR CAMERA LENS - ERROR 01 ON SCREEN
Clean the contacts between the lens and the camera.
Dec 30, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Getting scratching in the photos
There may be 2 chances
1. ur lens might have got those scratches. U might to change the lens in that case
2. Due to low light the scratch effect is appearing. U might need to change the setting accordingly
If not, you may need to contact the canon service
Dec 29, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Cameras Logo
112 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
