Question about Motorola Mobility SLVR L7 Cellular Phone
Automatic movemnet of the Keys in Keypad....
Hi all,
My problem is my applications are opened automatically.... ie even if close the application, the application in the opening screen opens automatically even though the key is not pressed.......
Please give me a Solution
Dev
    Brigadier General:
  • 7,752 Answers
Try having the firmware reflash on the phone
Posted on Aug 29, 2008
How many litters or quarters of oil in transmision need a toyota corolla 2000?
Check your Trans model...
Change only - 2.6 quarts. Total refill - 6.1 quarts.
Transmission model A131L
19554
Application: With automatic transmission
Note : A131L transmissionCoastal Dexron VI ATF
06812
Note : A131L transmissionCastrol High Mileage ATF
19509
Note : A131L transmissionCoastal Dexmerc ATF 5 Gallon
Transmission model A245E
Transmission Fluid Type/Capacity
159920
Note : A245E transmissionPennzoil Multi Vehicle ATF
VV353
Note : A245E transmissionValvoline Dex/Merc ATF
Good luck.
Apr 25, 2011 | 2000 Toyota Corolla
Some keys of my hp 2133 netbook is not working..wat should i do?
Restart the computer in safe mode (procedure is given below)
Start the computer and keep tapping the F8 Key on top of the keyboard
You will be in advanced options menu,
use your up and down arrow keys on the keyboard and choose safe mode and hit enter.
In safe mode close if any window opens, open note pad or any application and test the keys, it it is not working even in safe mode, then the issue is with the keypad, you have to get it replaced.
Mar 14, 2011 | HP DC170B Keyboard
How do I unlock and lock my nokia 1209 keypad to avoid **** dialing?
hi,
press MENU then asterisk * and your phone will be locked..to unlocked it just repeat the procedure...if you want automatic locked of your phone do this....
*MENU
*SETTING
*PHONE SETTING
*KEYGUARD SETTINGS
*AUTOMATIC KEYGUARD
*you have option there ON and OFF ,select ON
now your phone is in automatic locked status ,even you forget to locked it ,it will be safe and avoid dialing...
i hope it will help you ,thanks for trusting fixya..
Jun 20, 2010 | Nokia Cell Phones
What is the automatic transmission fluid capacity for a 1988 dodge ramcharger 4wd 5.2L engine
To find the correct specification, we need additional information about your 1988 Dodge Truck Ramcharger 4WD 5.2L FI 8cyl:
A999/32RH Transmission model
Transmission Fluid Capacity 4 Quarts
Application:
Fluid and filter change
Transmission Fluid Type 06810
Application:
Note :
Castrol ATF +4 ATF
Transmission model A727 or 36RH
4 Quarts
Application:
With lock up
Transmission Fluid Type 29201
Application:
Note :
Coastal(R)+4(R)ATF
06810
Application:
Note :
Castrol ATF +4 ATF
VV346
Application:
Note :
Valvoline ATF+4 Full Synthetic ATF
Lubrication chart for 1985-88 100, 200, 300 4WD
Hope helped (remember rated this post).
Feb 25, 2010 | 1988 Dodge Ramcharger
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
Some applications are opening & closing
check your system is fully updated with anti virus program, if not could be a virus problem, update the system and remove the virus, also check if you had recently installed any programs, that might had caused this problem then uninstall it..
Nov 10, 2009 | IBM ThinkCentre M50 PC Desktop
The instant message application on my nokia N95 keeps opening
check the buttun or keys maybe some key pressing down.. what or try to remove the keypad then observe the it.. if the same problem bring to the shop to fix for you
Sep 14, 2009 | Nokia N95 Cellular Phone
How do I lock the keypad?
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
K530i To manually lock the keypad:
  1. From standby, press the * key.
  2. Select 'Lock keys'.
To activate automatic keylock:
  1. From standby, select 'Menu' > Settings.
  2. In the General (tab), select Security.
  3. Select Automatic keylock > On.
To unlock the keypad:
  2. Select 'Unlock'.
Mar 31, 2009 | Sony Ericsson K530i Cellular Phone
Lock the keypad
K800i To manually lock the keypad:
  2. Select "Lock keys".
  1. From standby, select "Menu" > Settings.
  2. Select "Unlock".
  3. hope this helps Thanks and God bless
Dec 15, 2008 | Sony Ericsson K800i Cellular Phone
Some menu automatic update key not work
hi
i think thiers a prob in your switch. try opening your phone and try cleaning your keypad boards. maybe it is shorted or get dirty inside...
hope it helps...
Jul 10, 2007 | Sony Ericsson K510i Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
