Question about SanDisk Sansa e260 MP3 Player
E260 Ever since i downloaded these two songs, everytime i turn on my player it says that everything is empty. My songs and playlists. But, when i plug it in to the computer, it says i still have all my songs on it. Even when i look at the memory on my phone is still says i have songs on it. How do i fix this!
    Problem Solver:
  • 6 Answers
I'd suggest formatting it and synching all the music back onto your mp3 player. Formatting it deletes all the music from it by the way.
To format:
1. Open up your Windows Media Player.
2. Right-click on the Sansa e260 in the menu on the left and click format.
There's also a more complex method, so if that method doesn't help just comment.
Posted on Aug 28, 2008
SOURCE:
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
I have a sylvania mp4 smpk1021.i wanted to put new playlists on and deleted the old ones. it said "empty disk".i try to add new playlists, but songs that have already been added before are somehow still on...
is it posible to format the whole player from the computer or reset the player so that all the files are erased from it so you can add new playlists, like doing a hard reset to factory settings and erasing everything if it is possible to format it from the computer i wouldnt do it if it shows files that the player needs when you plug it in to the computer but i suggest doing a hard reset on it heres the manual link http://www.curtisint.com/web/browser.asp?productID=SMPK1021&catName=&brand=SYLVANIA&manual=SMPK1021 it might tell you in there how to hard reset it or how to fix it
Jun 04, 2009 | iLO MP3 Player
Zen nano mp3 player always starts at same song 1gig
You can put it on shuffle mode, and then it will play a new song everytime. Also, check if somehow you got some songs into a playlist or folder. If that is the case it may start from the same song everytime.
Apr 22, 2009 | Creative Labs Zen Nano Plus MP3 Player
When i want to add new songs to my sons rca jet all the songs
Place the new songs in their own playlist, name it something like 'temporary', or 'newest', etc. Save it, then sync that playlist to your player. It will be on there as a different playlist, but if you want them all to be in the same, you may have no other choice but to overwrite them all everytime. Not really sure either if there's an option in Media Player to add only the new ones.
Apr 09, 2009 | RCA JET S2002 MP3 Player
Ipod shuffel
heres what you gonna do
1. you should have an ITUNES installed on your computer and if you dont have download it on their website.
2. everytime you plug your ipod it will be recognizable.
3. look for a song or music file that you like and make a playlist.
4. plug your ipod and it should recognizable with itunes.
5. drag a file from a music folder to the itunes
6. then when its there on the itunes use the add to playlist locating your ipod. by the way if you didnt use ITUNES for dragging music then it wont play on your IPOD.
hope that helps!
CHARCOIS
Jan 26, 2009 | Apple iPod shuffle MP3 Player
Ipod library empty
Drag the files into your iTunes Library and they'll be imported into the playlist.
May 18, 2008 | SanDisk SDMX1 MP3 Player
HELP ME PLEASE with my "sony walkman NWZ-B105F MP3 PLAYER."
make sure your downloading it to the right folder on the mp3 player its usualy the music folder or you can try and use windows media player here are some instructions for that option.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Apr 12, 2008 | Sony Walkman NWZ-B105F MP3 Player
Songs go into a scattered order.
It is possible that the memory or settings have been corrupted. Install and run the Philips Device Manager from the product CD.
Select the restore / repair option and follow the on-screen prompts.
This will re-install the firmware and format the player.
When the process has finished, restart the player. It will initiallize and then shut down again. Switch on again and you'll get an "updating" message. The player will now be empty. This should also cure the alphabetical list problem.
Feb 15, 2008 | Philips GOGEAR SA6045 MP3 Player
No playlist found
One of the pesky features of windows Media Player is that if you delete the song/playlist from the computer's harddrive, and then resync your device to that same computer, then oftentimes the song/playlist disappears. Reacquire the song/playlist, and then try resyncing to the goGear again.
-Tha Mp3 Doctor
Dec 06, 2007 | Philips GoGear HDD1830 MP3 Player
Creating+ Saving Playlists and Doubled Songs
If you open the Sansa as normal Win file directory, can you see them? Is "Show Hidden Files" enabled in the file options?
Jan 01, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
47 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
