Question about Hawking (H2WR54G) Wireless Router
My HWR54G wont work with RCA Cable modem(DCM425) at Comcast.net
I have no problem using HWR54G with DSL modem;but when I change to cable modem at comcast.net it works for a while then it stops working( all leds are blinking like it works normaly);my PC can work easily if directly connected to the. cable modem.Comcast technical people told me to change the router.
Changing from comcast.net to att.net. can I use this modem?
No you can't use the modem from Comcast with AT&T because Comcast is cable and AT&T is DSL an entirely different thing. Hope it works out. Sincerly, Nick
Jun 23, 2011 | Computers & Internet
I see that people are asking about driverss for the RCA dcm425 cable modem. I just bought a new computer, and I connected it to the my old dcm425 modem through a router and it works just fine. I didn't...
The trick about all this is that the software does not configure the computer, but the modem.
So once it has been configured through a computer then plugged to a router, any computer plugged to the said router will have access to the Internet.
The whole process of installing/configuring will happen if you replace the old modem and/or plug a new computer directly to the modem.
May 07, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
When connect the power I get all solid lights except for the Internet light. Reset does nothing. I got the Modem on Ebay from a past Comcast user. Any ideas? Is it a goner? Thanks... Darryl From Portland...
You have to notify comcast, to let them know you bought a new modem. Comcast uses a two way communications to all of there devices, and it is not setup on your new modem.
Dec 06, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
RCA DCM425. What coaxial cable do I use? The RG6
Contact your cable provider, you most likely have a signal issue related to poorly seated fittings, outdated or wrong bandwidth splitters, or low signal from outside feed. Quadshield rg6 is the best indoor residential application though. -Comcast tech
Oct 18, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Will dcm425 work on playstation 3
Check this thread:
http://www.digitalspy.co.uk/forums/showthread.php?t=555166
Feb 16, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Do I need to open ports?
There are no ports to open on the DCM425, as it's a cable modem, not a firewall. Earthlink/Time Warner will likely not be truthful when it comes to blocking ports on their end. Would it be possible to change the port that your PS2 is using?
Same goes for the bittorrent question, only I'd switch to uTorrent and different ports as well.
Nov 14, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My connection fall
Please describe the leds in front of the modem which led lights or blinking ?
Aug 17, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Open Questions:
Hawking (H2WR54G) Wireless Router Logo
185 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
