Question about Lexmark Office Equipment & Supplies
I cannot print any documents and not even a test page. tried the command prompt,restarting printer, and computer. checked printer default and so on; I cannot print at all.
    Scholar:
  • 93 Answers
Just Follow this Article of microsoft and don't look at the errors mentioned just do this
http://support.microsoft.com/kb/324757
and reinstall the laters drivers
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Regards
http://www.MyTechGuru.US
Posted on Aug 20, 2008
I have a inpiron 530 with a Photo 926 printer. It will only print the last page of a print job.
Hello randy,
This is going to take some troubleshooting.
Please try the following, and test after each change. Hopefully we can get this working for you quickly Verify that when you hit print it under print range that only the last page is selected.
Try printing a different document, this is assuming you've been only having the issue with one document. Try printing a different type of document, using a different program such as word, notepad, or even a multi-page website.
If any of these has worked for you then it has either narrowed it down to the specific document, or the program, re install the program in question.
If none of the following has helped.
go to start/run type cmd to open the command prompt type following net stop spooler net start spooler this will restart the print spooler service.
If none of the above worked, delete the printer and reinstall. If problem persists install printer on a separate computer to verify that it works correctly.
Good luck, and I hope i was helpful.
Aug 14, 2011 | Dell 946 All-In-One InkJet Printer
Printing but page comes out blank
To allow for full use of the cartridges, some printers continue to print even after the cartridges are completely out of ink. First, check the ink levels. If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
If not, try to restart the printer. Restarting the printer might clear the issues and allow the printer to function correctly again.Press the power button to turn-off the printer then unplug the power cord from the back of the printer, and the USB cable(if connected). Leave unplug for 30 seconds then reconnect the USB cable and the power cord.
If issue persists, try to reboot your computer. Restarting your computer might resolve the issue. If the printer prints all pages correctly, but it adds blank pages to the printout, check for blank pages in the print preview.
If the preview contains no blank pages, check the printer cables. If the printer connects with a USB cable or an Ethernet cable, a faulty connection might cause the issue.
If the issue persists, check the printer settings on the computer. Issues with the printer settings on the computer might cause the issue. Follow these steps to check the computer: Step one: Check the default paper settings. Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)).Follow these steps to check the default paper settings.Click Start then go to Printers and Faxes .Right-click the icon for your printer (c01532298.gif ), and then click Printing Preferences . Under Printing Preferences window click the Features tab. Compare the settings in the Size drop-down menu with the paper in the tray. If the size of the paper in the tray is not the same as the setting in the Size drop-down menu, change the setting:Click the Size drop-down list, and then select More . The Size is window opens.Select the size of the paper that is in the tray, and then click OK .Click OK in the Printing Preferences window, and then click OK in the Properties window. Step two: Print a test page A test page might help determine if the printer installation caused the problem.Click Start , and then click Control Panel .Right-click the Printers and Faxes folder (c01532297.gif ), and then click Open.Right-click the printer icon (c01532298.gif ).Click Properties .In the General tab, click Print Test Page . The printer prints the Windows XP Printer Test Page.If the Windows XP Printer Test Page prints successfully, you do not need to continue troubleshooting.
If the page is blank, print from an alternate program to determine if the current program is causing the issue.Browse to the location of your saved document, right-click the file, and then click Open With .Select a program other than the program you are currently using to print the document.Open the file in the program, and then check the contents.(Most files open in plain text applications, such as Notepad or WordPad, even if the contents include unusual symbols or text that does not make sense). Try to print the file. If successful, the printer prints exactly what displays in the program window. If the document prints successfully in the alternate program, you do not need to continue troubleshooting. The issue is likely specific to the program you are trying to print from. Consult the program manufacturer for assistance. If the document still prints blank pages in the alternate program, disconnect other devices. Other connected devices, such as scanners, MP3 devices, or other printers might cause conflicts in the communication between the printer and the computer.
If the issue persists, go to this link for the rest of the troubleshooting steps. Go directly to solution nine. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&cc=us&lc=en&dlc=en&product=3390949&tmp_track_link=ot_search#N46
Apr 03, 2011 | HP DeskJet F4280 All In One Printer InkJet
Printer will not print anything except test page and wont delete
Possibly, the print spooler needs to be restarted. In Windows, one of the ways to do this is in the Command Prompt window. (Start > Accessories > Command Prompt, right click on the command and choose Run as Administrator in Vista or Win7).
Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. After the last command finishes, restart the computer. Check that the queue is empty and retry printing.
I hope this helps.
Apr 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
I cannot print a document from the computer
Try a new data cable. Check that the USB port is working - try a new port and check if a known-working device is seen by the computer. If you use a print server or a hub, try a direct connection to the computer.
Do you have the latest driver for your device? Check the Dell web site.
Is the print queue holding any documents? What does the Devices and Printers Control panel say about the printer status? If the printer is listed as ready but has jobs in the queue, you may want to stop and restart the spooler. In all versions of Windows since Win95 at least, you can do this in the command prompt (Run as Administrator in Vista or Win7). Type "net stop spooler" <hit enter> without the quotes; at the next prompt, type "net start spooler" <hit enter> again without the quotes. Restart the computer.
I hope these ideas help.
Apr 07, 2010 | Dell V305w All-In-One R840635AU InkJet...
HP Officejet J4580 All-in-one SerialNumberJob
open command prompt and give following commands
net stop spooler
net start spooler
repeat 34 times restart computer
Dec 16, 2009 | HP OfficeJet J4580 All-In-One Laser...
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Dell Laser Printer 1720dn Will only print test pages. When attempting to print a document, I click on 'Print', and the command is sent to the printer que, but the printer doesn't print. I've tried deleting...
Check that the correct printer is set as default. Also use File Print so that the selected printer is shown rather than using the Print button. If the test pages are being printed from the computer then the communication is working.
Dec 31, 2008 | Dell 1720dn Laser Printer
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
Sep 16, 2008 | Office Equipment & Supplies
147 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
