There is a drain pump system on the machine could be clogged, also if the drain hose is not installed up and over the unit it will cause issues with drainage. as for the rattling noise you probably have either pieces of broken glass rolling around under the basket.if you are a do it your self-er its always fun to explore.if not the cost of repair would be the cost of a new install. don't waste your money.
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Dishwasher not
draining issue usually occurs due to kinked drain pipe, clogged drain filter or
drain pump. Check the drain hose for any visible clogging, remove if present.
If no visible lint is present then remove then turn off the dishwasher and remove
the drain hose and check for any visible clogging. If still not visible then
the drain filter or drain pump is clogged and you'll need to clean the drain
filter and drain pump. Also, check for any food pieces stuck near the pump
impeller.
Please note that
dishwashers don't drain out the complete water such that heating element
doesn't overheat.
Hope this helps...
Daniel
Hi
Dishwasher not
impeller.
Please note that
doesn't overheat.
Hope this helps...
Daniel
