Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite He 4 model number 11085087400
This is regarding my earlier posting : Dryer on pressing the start button , three beeps and then nothing. The drum light was also off. I now ran the diagnostics test it and it gives me a 4E. what does that mean
thanks a lot
Ash
  • Anonymous Aug 20, 2008
    Thanks for the help. Could you also guide me through a step wise process on how to replace this switch starting from where its located.
    your help is greatly appreciated. This is my first exp with mechanical stuff.
    thanks much,
    Ashima
  • Anonymous Aug 21, 2008
    Thank you very much. That indeed is quite a lot of dismantling work. But I would try opening the machine this weekend.
    Thank you once again.
    Ash
  • 5,911 Answers
Sorry to take so long getting back to you. 4E is a door latch error code. It means your door latch is not working. Double check the wiring to make sure you don't have any loose or broken connections. More than likely, you will have to replace the switch. This is not one of your standard error codes that you will find in any tech sheet. I have experienced this problem before. If you go to searspartsdirect.com and type in your model number, you can find a replacement listed under the "Cabinet Parts" heading as item number 41 (part number 8519323). HINT: If you order this as item number 19 (part number 8283288) it also includes the wire harness. I hope this helps you. If you require additional assistance, please let me know. Good luck to you.
Posted on Aug 20, 2008
  • Jeff Rockwell
    Jeff Rockwell Aug 21, 2008
    Okay, the door switch is located near the 12 o'clock position with the door open. This is a push button switch that enables the dryer to run and turns the drum light out when the door closes. In order to get to it to replace it, follow these steps:
    1. First and foremost, UNPLUG the dryer. There are still live voltages present on many of the dryer components, even with the dryer turned off.
    2. Remove the dryer top panel by removing the three screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel slides back, then off.
    3. Carefully remove the operator control panel. There may be a couple of screws holding it in place. Carefully disconnect the ribbon cable going to the panel and the lift the panel straight up. The whole unit slides out. NOTE: You may have to loosen the screws on the Main Control Board (mounted to the top left of the drum) in order to uninstall the operator control panel.
    4. With the operator control panel out of the way, now remove the lower panel under the door. This is accomplished by loosening the screws under the bottom edge of the panel. With the screws removed, the panel should drop down, then off.
    5. Open the dryer door and remove the lint screen. Close the door and reach inside the bottom of the dryer and disconnect the Auto Dry Sensor plug (yellow wire) and the ground wire mounted to the dryer frame (green).
    6. Remove the air blower cover. This is located directly under the door and covers the blower fan assembly. There will be a few screws holding it place. NOTE: If you forget to remove the lint screen, you will have difficulty getting the blower fan cover off.
    7. Remove the dryer front panel. There are four screws holding it in place (two at the top and two at the bottom). You only have to loosen the bottom screws. Do not take them out all the way.
    8. Open the dryer door and grasp the top portion of the door open. Lift straight up and turn the panel slightly counter-clock-wise. There are drum roller supports on the panel that support the front of the dryer drum. Turning the panel will allow the rollers to come free of the groove they ride in on the drum.
    9. The switch should be accessible at this point. Disconnect the wiring harness. The switch is usually held in place with a couple of retaining clips. The clips have release tabs that you push in on and then the switch should come out from the front of the panel.
    10. Reinstall components in the reverse order of how I instructed you to disassemble them.
    HINT: You can remove the dryer door, if you like, to take some weight off the front panel. This can also safeguard the plastic window from getting scratched or broken. If you wish to remove it, support the weight of the door with one hand and loosen the screws holding the hinge to the door frame.
    NOTE: Refer to the Sears website I referenced in my earlier posting. There very helpful drawings for each section that can also assist you in locating components and with how to disassemble.
    I know it seems like a lot just to replace a switch, but this is the only way I know of to get the job done. If you experience any problems, let know. I hope this helps.
6ya staff
SOURCE:
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Model 110.C85081400 dryer manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kenmore model by clicking the link below.
https://www.searspartsdirect.com/partsdirect/user-manuals/11085087400-kenmore-elite-parts-manual
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Oct 17, 2010 | Dryers
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
When I push start it beeps 3 times. Lights on the right work, lights on the far left don't light up.
Alright, pretty unconventional, but simple and Genius on my part!!! Not sure if we're talking about the same models, but I was cruising this site with the same problem.... K, so it's making three beeps right? Check inside the DRYER (maybe same issue w/ washer, I dunno), but there's a button on the top-inside.... DEPRESS THAT BUTTON, and while holding it down, START THE DRYER (HOLD TO START), if it starts working, this tip is for you!
1) on the opposite side, where the door depresses that same button on the dryer door... you ready for this... see step two ;)
2) SUPER GLUE A PENNY IN THAT INDENTATION PART, your problem is there's not enough connection, and the door is no longer holding that same button down...
3) TA DAH!! Since a repair guy could've charged ya like 50+ bucks, I'll take... emmm.. 25$, email me at [email protected] on where to send the check, or just shoot me an email to say thanks ;)
May 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
4E problem on kenmore dryer
Same problem, no panel lights, nothing, but drum light works. Several postings on othe sites say the cuicuitry board is faulty. Sears, in the Phillippines, or India, do notheing. Paid lots for this dryer, live alone and really don't abuse it or even use it that much. Is the there a class action suit maybe? all I want is for it to work!
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer model no. 110.85087400 won't start
hello
i have a kenmore model 110.85087400 that will not heat up i just replaced the heating element and still have the same issue.what do you think it can be...when i open it to replace the element i notice some lint that was burnt...help please.miguel
Aug 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Jun 24, 2008 | Kenmore Elite HE4 Electric Dryer
HE4 Elite dryer beeps
The Thermal fuse is most likely the problem.
Nov 27, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
640 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
