Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
KV-36FS200 WEGA Initial Setup Annoyance
My set is about 6 yrs old. It has begun showing the Initial Setup Request on a very frequent and intermittent basis. Very annoying. Even after running the set up procedure it continues. The Sony site gives "RESET" instructions for this trouble but it also does not do the job. What's wrong? About how much will it cost to fix? Should I shop for a new set? H-E-L-P P-L-E-A-S-E
Thank you
  • allmiles Sep 06, 2008
    Frequently the "initial setup" screen will pop up over my screen. I can't seem to get it to stop. Please help.
  • bswiss Oct 12, 2008
    I've been told this problem stems from liquid screen cleaners seeping onto the front control panel terminals causing bad connections and that sometimes rapid pressing of all the buttons sometimes clean the controls. Well I tried this and my set is working again without ever opening anything. I hope I'm not giving myself bad luck talking about it. Murphy's Law?!?!?!?!
    Sergeant:
    Champion:
  • 227 Answers
Hello my friends i beleive that you have some loose connections on the main board around the eprom
good luck
caypianan@yahoo.com
Posted on Oct 11, 2008
  • ESTEBAN MERINO
    ESTEBAN MERINO Oct 12, 2008
    that is a posibility,but i seen this before.
My 11 yrs old 25"
No,the tv main logic pcb board have dead components parts on it and also the tv video boad too.This tv must take to tvs shops and get estamate see it is worth the priced to be repair or compair the prices could be cheaper just replace another tv.
Aug 10, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony trinitron wega kv-36fs200 36' tv is missing green color
sounds like a major fault with the line output transformer/power board. if no green on screen, tube is on it's last legs. Advise to scrap, not to repair, cost in excess of £200
Oct 23, 2009 | Televison & Video
Initial Setup Screen
Have you ever cleaned the set front glass with windex or glass cleaner.Sometimes the fluid runs down before you can wipe and lands inside right on top of the push buttons that control ( CH,VOL, MENU, etc.) If this happens you can get this trouble. If you up to it take the cover off and look at the board just under the front edge of the crt. If you see green or grey residue you probably have to remove that corresponding TAC switch. You can just cut out and use the remote for that function.
Apr 07, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Initial setup
This is commonly caused by the CRT going too weak, and the AKG circuits are switching off the bias to the CRT. This is part of the high voltage regulation protection.
Other causes, but are rare to cause this, are failures in the bias circuits, high voltage regulation (flyback assembly), and in the scan amplifiers.
With proper experience, reference to the service manual, and the proper set-up, it is possible to determine the causes of the failure, and service it. The cost of the parts will be rather expensive if you can still have access to them.
Jerry G.
Apr 04, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony KV-27FS100 does not respond to remote
Good day.
Maybe there are loose connections along the IC that supports the operation of your remote. This could also hamper initial set up operation of your unit. Also, check on loose connections along the power supply.
Chris
Mar 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Initial Setup flashing on and off
1) Do a hard reset = leave unplugged for 12-24 hrs , then
try again.......................................
2) What does "until the remote is disabled" mean ??
Nov 09, 2007 | Sony KV-32V16 TV
Initial setup
First give it a hard reset. To do this you must unplug the power cord for at least 4 hours; then try again.  This will reset the internal programming and restore it to factory defaults settings. Unplugging for a shorter period of time may not do the trick.
If the hard reset does not solve the problem it has a defective eeprom OR a bad voltage regulator that feeds the controller IC/eeprom set.  In which case you will need a tv tech to dignose the exact fault and determine the defective parts. (There are over 100 parts associated with these functions).
Hope this helps.
Oct 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
32" Sony Wega -- initial set-up menu constantly on
Came across this because I was having the same problem. I was getting the menu immediately. It started with the remotes not working with the TV, so I unplugged it. Afterwards, the initial setup appeared, but couldn't complete. I don't have anything connected to the tuner, everything is on video inputs. Don't know why it wouldn't complete, it would get 20-40 channels into it, and stop, and the "initial setup screen" appeared. I ended up turning off all peripherals, waited about 10 minutes, then running the setup. it finally completed the scan of the tuner channels, and has not appeared since. Perhaps just an accidental solution, but hopefully something in there helps.
Jul 26, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Heh. I just gave my set the "Fonzie treatment" after I was convinced the initial setup notice was messing with me. The problem cleared right up. No joke.
May 30, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
168 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
