Canon error canon machina ir 5055n give erroe E225-001 i check connector and replace scanning lamp and inverter PCB and your staff tell me ching the platen glass i do it but still indicate the error
  • Anonymous Mar 24, 2014
    it says platen/cover is open
    close platen/cover
  • 1,326 Answers
We do not work for FixYa.... This a free web site to answer questions you may have FOR FREE. I DO NOT GET PAID FOR THIS INFO........ OK, on the same page????? I have had this problem before, I, also ordered a lamp and the pcb and it did not work as well. I had to take a lamp and pcb from a working copier of the same mode to finally solve the problem. Try that first... It could also be a problem with the CCD unit?
Posted on Aug 22, 2008
Ir 3300 copier error code e000732-0001
Canon iR3300 Error Codes Code: E732-0001
Code
E732-0001
Description
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Causes
The connector has poor connection. The reader controller PCB is faulty.
Remedy
1. Connector, Reader controller PCB Is the connection between the connector J1014 on the main controller PCB and the connector J409 on the reader controller PCB normal? NO: Correct the connection. YES: Replace the reader controller PCB.
Below is the site this came from which lists all the error codes in case another occurs after you resolve this one
Canon iR3300 Error Codes List page 1 from 12
Aug 27, 2016 | Canon Ir 3300 Black & White Copier
What does the Canon IR8500 error code E000222-0000 means?
There's no code like that in my manual.It's220-001 means lamp inverter PCB faulty,or reader controller PCB faulty. There's also a E 225-000 error which mean scanning lamp(xenon tube) is faulty,or inverter or CCD
Oct 14, 2014 | Canon Office Equipment & Supplies
Canon iR 6000 is giving error code E000225-0000 solution please
Scanning lamp faulty,inverter PCB faulty,reader controller PCB faulty...
Sep 25, 2014 | Canon Office Equipment & Supplies
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
How do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
Dec 14, 2011 | Canon Office Equipment & Supplies
Error code E000202 0001
This is a code related to the scan lamp or the lamp inverter. Some times it's best to replace them both at the same time because I've had trouble mathing up the lamp connector to the inverter. Canon change these connectors from the old lamps to the new inverters. Good Luck
Jun 10, 2011 | Canon imageRUNNER 2200
Giving an erro E220(IR3300)
E220
0001 A fault is detected on the inverter PCB for the scanning lamp.
Main cause The inverter PCB is faulty. The reader controller PCB is faulty.
Action
1. Wiring
Is the wiring from the scanning lamp to the reader controller PCB normal?
NO: Connect the connector firmly, and correct or replace the wiring.
2. Inverter PCB, Reader controller PCB
Try replacing the lamp inverter PCB. Is the problem corrected?
YES: End.
NO: Replace the reader controller PCB.
Aug 02, 2010 | Canon imageRUNNER 2200
WHEN I SWITCH THE COPIER IR 2800 .IT SHOW;S ME ERROR E000220-0001 HOW DO I CLEAR THIS ERROR
E220
Action
1. Wiring
YES: End.
Pls. rate
May 11, 2010 | Canon Office Equipment & Supplies
Canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
Apr 07, 2010 | Office Equipment & Supplies
Canon problem
the problem may the platen glass!!!!!!!!!!!
is the platen glass ok, did you change it? is the white on the platen ok? it uses it for reference.
Aug 19, 2008 | Canon Office Equipment & Supplies
194 people viewed this question
jasbo
jasbo
