Question about Microsoft Xbox 360 Console
Xbox 360 console
My xbox is not opening its disc tray but when i take the face plate off it opens up and when i put the disc in and close it it says it openining what do i do?
e-mail me ur answer at [email protected]
sincearly,
tylr
  • 28 Answers
I had the same problem, thats a faulty drive, I could be that the heatsink under it is so hot that is making the drive faulty, So you'll have to open your xbox a put something between the heatsink and the drive. But if that doesn't work then you'll have to replace it with another drive and transfer the old firmware to the new drive so it can work on your xbox.
Posted on Aug 27, 2008
SOURCE:
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Feb 16, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
My new xbox keeps ejecting all the time. iv'e only had it for 4 months.
Do you have a custom faceplate on your system? If so, some after market plates have unshaved pieces of plastic that can push on the eject button. Another possibility is that your disc tray guide rails are clogged at the end and are not letting the tray close all of the way. That requires the system to be serviced.
Oct 28, 2010 | Microsoft Xbox 360 Console
When i put a game in my xbox 360 it says reading then open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 19, 2010 | Microsoft Xbox 360 Console
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
My X-Box 360 disc tray will not open, it starts to, but it never gets past the face plate, i think it's jammed, but im not sure, is there any way to get it open ??? HELP!!!
Try taking the face plate off and then hit the button with a small object. If it opens it's you faceplates's fault and you should try and get a new one. If it doesn't it's CD Drive's fault. You could take a butter knife to it and pop it open but I would suggest calling Xbox Customer Support first. Their number is 1-800-4MY-XBOX. They can help you out from there. You might have to send it in, sadly.
Thanks,
Brandonmxb
Dec 13, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
May 29, 2009 | Microsoft Xbox 360 Console
Xbox360/must open & close tray 5 to 10 times before game opens.
This is an indication that your disc tray / the lens on the tray is not working properly.
What i suggest is to call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
Apr 04, 2009 | Microsoft Xbox 360 Console
My disc drive wont open
if you can view the xbox with the faceplate removed theyres a section you can push in to eject the tray. my theory is your Band has snapped in the drive that ejects the tray
Feb 12, 2009 | Microsoft Xbox 360 Console
Xbox 360 disc
select the open tray and open it then close it. If tht doesn't work then pay for xbox repair, sorry, I'm having 360 problems, too. I'm just trying to help other people to improve karma, lol.
Jul 29, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
51 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
