Question about Canon Office Equipment & Supplies
My pixma pro 9000 Canon printer will continues to flash the yellow light and the on light and will not let the ink cartridges move to the middle to change the catriges
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmm..turn it off..unplug from wall outlet..let it set for 3 min
hold down power button, and plug back in wall..with button depressed.
release button after 10 seconds
that might reset the power situation.
Posted on Aug 20, 2008
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
All the ink tanks are not lite up. I was in the middle of a large print and before I put the first ink tank it did not light none of the ink tanks were lite.
There are a couple of possible problems.
1 A faulty printhead
2 Faulty or empty ink cartridges
3 The contact pins in the printhead could be dirty, covered, or sitting in a pool of water/ink generating a short-circuit.
Check all the cartridges have ink visible in the rear ink chamber, check the contact pins are clean and dry, make sure the chips on the cartridges are clean and dry. If all those are OK count the number of orange flashes the machine shows in a repeating sequence. 10 sequential flashes often indicates a trashed print head.
Jun 25, 2015 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Canon Pixma 9000 pro flash 14 times
Hello, this is what your error means: Ink tank not recognized [1684]
A non-supported ink tank is installed (the ink tank LED is turned off). Install the supported ink tanks, check that the chips on the cartridges are clean.
Oct 07, 2012 | Canon Uv Ink Refillable Cartridges For...
Pixma Pro 9000 Canon Printer is printing terribly colored photos.
You need to check your nozzle check print and see if all the colors print. Also many generic inks are not the right color. Take out your yellow cartridge and see if it's still yellow, if it's orange or brown you need a new printhead, there's a membrane inside that keeps the colors separate and when it breaks you get cross contamination of the colors.
Dec 23, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
How do I change the ink cartridge?
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head moves slightly to the cartridge replacement position, and the power light flashes when the print head is in position. Do not move the print head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow tape seal from the cartridge. The yellow tape seal must be removed. Leaving the tape on when you install the cartridge will permanently damage it. Do not remove the tape seal from the bottom of the cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on the cartridge face up and the arrow on the cartridge pointing to the rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and begins charging the ink delivery system. This process may take a few minutes to complete. The power light continues to flash while the printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so can result in incomplete charging of ink. Even if you do not press the cleaning button, the printer moves the print head and begins the ink charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
You are now ready to print.
Oct 18, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
"WRONG CARTRIDGE" continues to flash on the screen.
I have experienced the "Wrong Cartridge" error about 4 times in four years. I have never bought a replacement print head. I do occasional printing each week. Typically the problem occurs after a color cartridge goes empty and the ink dried to the print head. The solution for me has been to remove the cartridges, remove the print head, place the print head in hot water in the kitchen sink (softens water based ink that has hardened)and then use a Q-Tip or tissue paper to clean the print head until it is nice and shiny. Reinstall the print head, insert ink cartridges that are not empty, let the printer cycle through a self-test, use the set button to accept vertical and horizontal print patterns and you'll be good to go!
If that doesn't fix it, you'll need to replace the printhead ($49-69 depending on where you buy it.
Oct 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My Canon ip1600 wont print with new ink cartridge.
Visite the support tech and try to find a answer for you probelem:
Sep 09, 2009 | Canon PIXMA iP1600 Printer
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Since replacing 2 ink cartrides the printer doesn't work. The on/off light is flashing yellow
Have you tried unplugging the power cord from the back of the printer waiting a few seconds and plugging it back in. This may help it recognize the cartridges.
Apr 24, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
HOW LONG HAS YOUR INK SAT IN THE PRINTER WITH OUT USE AND IS IT A CHEAP INK THAT YOUR USEING ? IF SO THAT COULD BE THE PROBLEM
Apr 05, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
158 people viewed this question
old marine
old marine
