Question about HP L1906 19" LCD Monitor
Monitor problem hi, i need help from you. my monitor can't display picture from pc and the screen is green when i plug in to the pc but when i pull this out it geting black and show the screen that don't have signal from pc. when i asked to may friend he told me maybe the problem is from your board vga in your monitor. if that true where is i can get that board ?. thanks. and this my email:wiwit.wahyudi@globaltv.co.id
    Scholar:
  • 93 Answers
This Could Be a problem with the Port on the Motherboard try the display on your other system or a friends system
if it works fine then the system board has the issue otherwise its the issue with display
Posted on Aug 20, 2008
Screen now is pale green and print is fuzzy
You are probably right. The inverter supplies the voltage needed to light up the screen and power the lcd. If I were to tackle this repair I would sub a laptop monitor in place of yours and then troubleshoot the monitor. Inverters have a fairly high failure rate
Apr 22, 2010 | Dell Inspiron B130 Notebook
Hi I am running Triple Acer AL1912 LCD monitors on a Mo-View triple monitor stand. I have run these for a couple years without fail. PC is running 2 video cards a NVIDIA GeForce FX 5600 and a NIVIDIA...
Most comon problem with monitors are bad caps in the power supply, any good reapair shop should be able to fix them easily, see pictures of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
At least you will have some info so you will not get ripped off by repair shops.
Mar 01, 2010 | Acer AL1912 19" LCD Monitor
Color output to screen lacking red
You have ruled out the graphics chip by plugging an external monitor in, the chips fine.
Now you have to look at the inverter. Sometimes a cable will work itself loose from the inverter, causing the display to go wild and show strange colours where is should be white.
What you have to do is remove the screen bezel (the plastic screen surround) this reveal the screen, look at the bottom of the screen for a thin circuit board with cables coming from it and make sure the cables a plugged in properly.
If you need anymore help or advice please post back.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
Monitor wont display a picture
plz try by resitting the ram if it doesn't work then *********** board require servicing
Mar 16, 2009 | Microsoft Windows 98 for PC
Acer CRT moniter 17" Model: AC713 dost not display any thing.
Ok if you prese the menu button on the monitor does the monitors setting menu appear on screen
If it displays adjust the contrast and brightness until a picture appears
If that does not work place a fringe magnet on one of the corners of the monitor if there is now green tinge around it than there is no electrons being fired at the screen and you have missed something so test every component
Mar 14, 2009 | Acer AC713 17" CRT Monitor
Monitor goes dead after after switch on after 3seconds
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Mar 09, 2009 | GNR 19M1 19" LCD Monitor
No sound on lcd monitor
Hi...there,
Very simple just plugged your audio cable to your lcd monitor jack , then do the same to your pc audio jack. From the front (with picture of a headphone) or from the back (green audio jack) To settings the volume control open the on screen display from the lcd monitor and look for volume settings. or go to your toolbar bottom r/h side look for the icon of a speaker and click on it...and that it... have nice a day!
Jan 13, 2009 | Fuji FP-988D 19" Flat Panel LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
If it's working fine in DOS, it can only be your display drivers for your operating system. What happes when you start in SAFE MODE? When you PC starts, keep pressing the F8 key, go to Safe Mode. If it works, bring the Resolution down to 800 X 600 and load the new display card drivers. Restart, should be fine.
Apr 22, 2008 | Philips Standard 104S 14" cRT Monitor
HP L1906 19" LCD Monitor Logo
104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
