Question about Cameras
I have a fugifilm finepix 2800zoom and I just lost all my pictures because I was trying to set the date and pushed format and didn't realize I was in the erase screen. Are they gone forever? I am literally sick because they were all the pictures I have of my babies. Please Help!
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Posted on Aug 20, 2008
Need window 7 drivers to convert my finepix 2800z camera to sweb cam
ø the selector switch must be in the middle, the image that's between the camera and the movie camera, (the power button), plug in the USB, power up the camera, from there, Windows should find the device and cause it to show up as a removable drive
ø format your media card, that will put the folder back. All you have to do is right click the drive that shows up when you plug-in your camera, click on format and all will return. The different user issue is a odd. You my have chosen just this user instead of any user that uses this computer.
ø have the FinePix 2800Zoom, may be able to help you out. On your media card that goes into your camera, you should see a folder named 100_FUJI. That folder must always be there so that when you take pictures, it has a folder to be saved to.
Aug 18, 2011 | Computers & Internet
I want Date & time stamp on pictures
Hello and Welcome
To set the date and time stamp on pictures, Follow the given instructions:
  • Power on the FUJIFILM FinePix J28 digital camera and wait for the hardware to finish running through its start mode
  • Press the "Menu" button on the rear of the device, then choose "Setup."
  • Select "Options," followed by "Date." This brings up the date display. The display blinks as it has not yet been set.
  • Push the top button on the control display to advance the first number in the date. Once you have the correct number selected press "Enter" and repeat the process for all the numbers. When the date is set the time information appears. Follow the same procedure to set the time. Press "Enter" to accept the changes. Now every picture captured with the FUJIFILM FinePix J28 will save the date and time to the pictures
For further assistance, I am here to help.
Thanks and Keep Visiting FixYa
Apr 02, 2011 | FUJIFILM FinePix J28 Digital Camera
How do i erase pictures on a fugifilm a700?
1) Press MENU/OK to open the playback menu.
2) Press the left or right arrow buttton to select Erase.
3) Press the UP or DOWN key to select FRAME or ALL FRAMES.
4) Press MENU/OK to confirm selection
This should work. Good luck!
I Can Fix It.
Aug 14, 2009 | Fuji FinePix A700 Digital Camera
My fugifilm finepix A805 has ! FRAME NO. FULL and my card is now empty. It won't let me take pictures and I can't get that message off my display screen
Your Counter has reached 999.999
Here's what you do.
Make sure you have no pictures on your card to start with.
Place the card in the camera and turn it on.
Press "Menu" and go to the "Set" menu and select "Format". This will wipe your card completely clean. When this is done select "Frame No" in the set up menu and set it to "Renew".
Now come out of the menu options and take a picture.
When you review your picture the counter should read 100.001
Now go back to the set up menu and reselect "Frame no." and set to continuous ("Cont.")
Happy snapping
Jul 12, 2009 | Fuji FinePix A800 Digital Camera
Need to change the date of previous taken pictures
load the pictures to an computer and click on characteristic trait
and rename the date
Apr 03, 2009 | Fuji FinePix A340 Digital Camera
I bought a Fugifilm FinePix J110w in November. It won't upload
Try updating the software to upload your pictures, or get a sd flash card reader.
Feb 24, 2009 | Fuji FinePix S3000 Digital Camera
Fugifilm finepix camera won't read memory card
Hi there.
Pop the card in the camera, then use the camera's menu to format the card, if it formats you should be good to go.
Good luck and thanks for using Fixya!!!!
Feb 11, 2009 | Fujitsu Cameras
The memory card is re-formatted by selecting the FORMAT option in the camera's set-up section in the main memory. It will ask you to verify that you wish to re-format and then erase all of the data on the memory card so that you can start using it.
Jul 10, 2008 | Fuji FinePix F11 Digital Camera
Lost My Software For My Fugifilm A350 - 5.2 megapixels
This could be a faulty cable. Windows Moviemaker is part of XP and should deteck the camera. Can you beg or borrow a cable to check this out?
Sep 09, 2007 | Fuji FinePix A350 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
