Motorcycles Logo
Posted on Jun 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front disc brake is very spongy, sometimes it grabs properly but mostly the brake is useless (pads are fairly new)
Anonymous
Level 2:
Scholar:
  • Expert 107 Answers
  • Posted on Jun 14, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
107
Questions
0
Helped
46196
Points
237
Try bleeding it first. If there isn't any air in the system, you have a brake hose collapsing internally. Replace the hose, flush the system, bleed the air out and you'll be fine. Good luck!
1helpful
2008 VOLVO REPLACED FRONT DISC PADS DID NOT OPEN BRAKE SYSTEM OR LOSE ANY FLUID NOW HAVE SPONGY BRAKES
New brake pads can cause a spongy feel until they "cure". This means that they have to heat and cool a few times and have the initial outer layer wear smooth to the disc before they become fully effective. If, after a week or so there is no improvement, check the caliper slides to ensure they move freely and there is no rust or binding occurring as this can affect braking strength.
Change front brake pads, 2002 FXD
For 2002 DYNA to replace front brake pads FIRST remove the front master cylinder reservoir cap because as the pistons are pushed back into the caliper the fluid level may rise and you will need to see this and may have to remove some excess fluid, the3n loosen but do not remove both (12 pt/0.25 in.) pad pins, remove both 10 mm caliper mounting bolts, detach and remove the caliper from the front forks and brake disc, pry the pads back to force all four caliper pistons fully into their bores, with the pistons retracted, remove the pad pins and brake pads. The front left, front right (if present as not present on all motorcycles) and the rear brake calipers use the same exact brake pad set. On the right side of the vehicle, the pad with the two tabs installs on the inboard side of the caliper and on the left side the pad with the two tabs installs on the outboard side of the caliper. Install new brakepads into caliper with the curved portion of the pad facing the rear of the motorcycle, loosely install the pad pins until you hear an audible click, attach the caliper to the front fork, on models with dual front calipers check the alignment of the brake discs to the calipers. Loosen the axle pinch bolt nuts, tighten the axle nut to the proper torque, insert a 7/16 in. drill bit through the hole in the axle as far as it will go so that the contact point will have the edge of the drill bit touching the edge of the fork leg, place the caliper over the brake disc with the bleeder valve facing upwards, loosely install the long 12 pt/10 mm mounting bolt into the top hole on the fork leg, install the short 12 pt/10 mm mounting bolt into the bottom hole on the fork leg, tighten the bottom mounting bolt to 28-38 ft-lbs (38.51.5 Nm), final tighten the top mounting bolt to 28-38 ft-lbs (38.51.5 Nm), final tighten both pad pins to 180-200 in-lbs (20.3-22.6 Nm)., on models with dual front calipers, tighten the pinch bolt nuts while holding the slider against the 7/16 drill bit if necessary, remove the drill bit, pump the brake hand lever to move the pistons out until they contact both brake pads, verify the piston location against the pads and if the front wheel is off the ground, rotate it to check for excessive brake pad drag, check the brake fluid level in the master cylinder and fill it to the proper level if necessary using D.O.T. 5 SILICONE BRAKE FLUID, install the master cylinder reservoir cap and tighten its cap screws to 6-8 in-lbs (0.7-0.9 Nm), turn ignition switch ON pump the brake hand lever to verify operation of the brake lamp, test the brakes, test ride the motorcycle and if the brakes feel soft or spongy, bleed the system until you get a firm/hard brake lever and avoid making hard stops for the first 100 miles (160 km) to allow the new brake pads to become conditioned to the brake disc(s).
1helpful
REplaaced brake pads and spped sensor on 2006 gmc sierra now brakes are spongie at times and have bled them.
DEPENDS WHAT PROCEDURE YOU USE TO REPLACE THEM.IF YOU PUSHED THE CALIPER PISTONS IN WITHOUT OPENING THE BLEEDER AND USING A **** CLOSED THE BRAKE HOSES YOU MANAGED TO SENT BACKWARDS THE FLUID INTO THE MASTER CYLINDER WHERE IS THE POSSIBILITY TO CAUSE THE SEALS ROLLING IN AND ARE NOT HOLDING PRESSURE. THE OTHER REASON IS EITHER YOU NEED TIME UNTIL THE BRAKES BED ON THE DISCS SURFACES.
2answers
How do I adjust rear brakes on '03 Hyundai Elantra
bleed the brakes so that there is no air
spongy pedal
apply the foot brake and use the hand brake to adjust the thread to the back of the piston
the slots in the pistons are only to screw the piston back along the thread to get the new pads in
How do i change front brake pads on my 2002 fxd super glide
emove the front master cylinder reservoir cap because as the pistons are pushed back into the caliper the fluid level may rise and you will need to see this and may have to remove some excess fluid, the3n loosen but do not remove both (12 pt/0.25 in.) pad pins, remove both 10 mm caliper mounting bolts, detach and remove the caliper from the front forks and brake disc, pry the pads back to force all four caliper pistons fully into their bores, with the pistons retracted, remove the pad pins and brake pads. The front left, front right (if present as not present on all motorcycles) and the rear brake calipers use the same exact brake pad set. On the right side of the vehicle, the pad with the two tabs installs on the inboard side of the caliper and on the left side the pad with the two tabs installs on the outboard side of the caliper. Install new brake pads into caliper with the curved portion of the pad facing the rear of the motorcycle, loosely install the pad pins until you hear an audible click, attach the caliper to the front fork, on models with dual front calipers check the alignment of the brake discs to the calipers. Loosen the axle pinch bolt nuts, tighten the axle nut to the proper torque, insert a 7/16 in. drill bit through the hole in the axle as far as it will go so that the contact point will have the edge of the drill bit touching the edge of the fork leg, place the caliper over the brake disc with the bleeder valve facing upwards, loosely install the long 12 pt/10 mm mounting bolt into the top hole on the fork leg, install the short 12 pt/10 mm mounting bolt into the bottom hole on the fork leg, tighten the bottom mounting bolt to 28-38 ft-lbs (38.51.5 Nm), final tighten the top mounting bolt to 28-38 ft-lbs (38.51.5 Nm), final tighten both pad pins to 180-200 in-lbs (20.3-22.6 Nm)., on models with dual front calipers, tighten the pinch bolt nuts while holding the slider against the 7/16 drill bit if necessary, remove the drill bit, pump the brake hand lever to move the pistons out until they contact both brake pads, verify the piston location against the pads and if the front wheel is off the ground, rotate it to check for excessive brake pad drag, check the brake fluid level in the master cylinder and fill it to the proper level if necessary using D.O.T. 5 SILICONE BRAKE FLUID, install the master cylinder reservoir cap and tighten its cap screws to 6-8 in-lbs (0.7-0.9 Nm), turn ignition switch ON pump the brake hand lever to verify operation of the brake lamp, test the brakes, test ride the motorcycle and if the brakes feel soft or spongy, bleed the system until you get a firm/hard brake lever and avoid making hard stops for the first 100 miles (160 km) to allow the new brake pads to become conditioned to the brake disc(s
2answers
Just changed front brake pads and still feels like brakes go to the floor. What is wrong?
check that fluid level is ok, by changing pad and opening calipers you may have lost fluid our of resovoir.
if your discs where not changed or skimmed at the same time you will have ridges, that do not match to the smooth pads, when you drive for a few miles eventually the pads will wear down and form the shape of the discs.
if they continue to be soft, bleed the fluid to make sure there is no air in it, if the brakes are still soft after this you should replace the brake fluid completely if it has not been done for a while as brake fluids absorbes moisture and that makes the brakes feel spongy or soft.
i hope this was useful.
2helpful
My rear brakes on my 1996 GMC Yukon lock up fairly easy (pads are good) when the brakes are applied. It's like they get most of the stopping power vs the front brakes (new pads/rotors). The booster is...
W hen the rear work fasterr than the front or any wheel grabs faster then you need to check the brake hoses. In your case the front brake hoses could be starting to clog up. they deteriorate from the inside and collapse
The dealer just performed a brake job on the front disc on our 2005 Nissan Pathfinder - new pads; turned rotors. Now the pedal is spongy. What needs to be done or checked.
If the brakes are spongy after a brake job the dealer should have blead them as part of the repair procedure...bleed the brakes and the pedal should firm up again.
1helpful
Suzuki GSX 600 F (1998) soft front brake, I have upgraded to braided hoses but brake lever still feels spongy, can I upgrade the master cylinder or do I have to accept them as they are?
you can renew the master cylinder seals, the calipar seals can also cause the lever to feel spongy, they grip the pistons and pull them too far back into the bores instead of letting them return just enough to realease the brake, in this condition when you apply the brake most of the lever travel is just pushing the calipar pistons out to reach the pads and the little travel that is left is pushing the pads on to the disc, hense the spongy feel
1helpful
2answers
Brakes feel spongy.when pressed hard goes nearly to floor.if pedal released slightly and pressed again feels normal.this is a 1997 toyota caldina GGT with abs.have bled brakes and sgimmed discs.any ideas?
Either you did not bleed the brakes properly or they need adjusted. (rear only) Front most likely are disks. If you put pads on the front and spread the caliper pistons, you should pump the brake pedal 10 or 15 times to move the pistons out. Some ABS systems are notoriously hard to bleed.
Top Suzuki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a Suzuki Expert? Answer questions, earn points and help others
