Question about NEC Computers & Internet
My nec multisync 1720m went blank and power light flashing green
  • 11 Answers
SOURCE: Power on Green but no display (blank screen)
In the LCD1830 the inverter for the backlight always burns out. They are fairly easy to replace when you remove the back to get inside. A new one is available from MoniServ for $69.99. http://www.lcdpart.com/Products/uhp061104mss.html
Posted on Apr 07, 2007
SOURCE: My NEC MultiSync LCD2080UX
I returned the monitor for a full refund. I'll keep shoping. Thank you for your responce and drop me a line from time to time. dipper19
Posted on Aug 06, 2008
Junoon007
  • 1011 Answers
SOURCE: when I awaken my NEC
Dear Sir/madam,
Click this link for more information....
http://www.princetongraphics.com/site/support_faq_lcd.htm
A light blinking at a rate of at least once every second often seems to be made to indicate there is a problem, as in the makers of the device that has the light did it to show that there is a problem, so at least the monitor "knows" there is a problem...So maybe you should read the manual or contact the manufacturer and see what the blinking light means.
First things I would try are to plug it into a different PC, trying a different data cable, a different power cord, and a different outlet. If all of the above fails (including reading the manual or contacting the mfr.), it is probably a part inside the monitor not working correctly. Make sure all connections are secure, and not crooked or anything, including the video card's (if there is one) connection the the motherboard's slot, any internal power cord to the video card, etc
thanks
good luck
Posted on Sep 18, 2008
Rifaa
  • 99 Answers
SOURCE: nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Posted on Nov 08, 2008
david344
  • 18 Answers
SOURCE: NEC FE2111sb multisync 21 inch monitor troubleshooting
the symptoms you describe sound like the monitor is going into 'greeen mode' - that is to say, it sees no video signal present. first, try another monitor ti isolate and make sure the problem is the monitor. check the vga plug pins [especially if you have recently moved and/or disconnected and re-connected the monitor. ifnent, 'wiggle' the vga cable, as i have seen the actual cable fail frequently. if it is the monitir, vheck the solder connections on the neck boar [the circuit board that the crt plugs nto. if all looks well, and it is a component, such as a cap [and yes, they're cheap, and there's a wide tolerance in value- that is you can replace it with one as much as twice the value in microfarads, and just ake sure you use one with a voltage rating at least equal to, and better yet, exceeding the rating of tf the original. good luck
Posted on Mar 07, 2009
My NEC MultiSync LCD1970NX monitor went black while in use and green power light is flashing.
If the system is booting up and if you see the "NUM LOCK" key lighting up in your keyboard then the system is working fine. The problem is with your graphic card. Check and repalce it. If not, the problem is with your monitor. Check the warranty and ask for a replacement.
Mar 03, 2011 | NEC MultiSync LCD1970NX-BK (Black) Monitor
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Feb 17, 2009 | NEC MultiSync LCD1810X 18.1" LCD Monitor
NEC MultiSync FE2111SB 22in monitor problem
a blinking green light usually indicates no video signal. check your cables, and if you have another computer, try it on that. otherwise, carefully check your vga signal cable, and the connections on the neck board [where the crt plugs into]
Aug 11, 2008 | NEC MultiSync FE2111SB 22" CRT Monitor
Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Jun 02, 2008 | NEC MultiSync 1550V 15" LCD Monitor
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
Jan 02, 2007 | NEC MultiSync LCD1830 18.1" LCD Monitor
Computers & Internet Logo
183 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
