Question about Shuttle AV40 Motherboard
No Power. I have a Shuttle AV 40 MB. It will not POST. It seems like the MB is not getting power. I have the correct power supply. 3 connections to the MB. Any ideas as to what the problem may be. Its driving me nuts!! Thanks, Ron!
  • crof4829 Aug 20, 2008
    It may be the power supply. I have rechecked my connections many times. Thanks for your help.
    Ron!!
  • 3,051 Answers
Have u had the power supply tested and if it is ok make sure that all of the connections are correct and in tact if still nothing then double check the bios jumper settings on the board
Posted on Aug 20, 2008
New shuttle x70 has a black screen will not post nothing at all please help
Make sure you have an internal speaker connected. Most new systems no longer include this speaker, but it is handy as it will sometimes beep when the system no go and that can help diagnose problems. Check all internal power cables are correct. RAM is seated correctly, CPU fan is attached. Then check power supply is not faulty
Nov 24, 2014 | Shuttle Computers & Internet
Can I get user manual for Nikon MB-40 multi-power battery pack for F6 body?
I think the extent of the instructions is on the Nikon USA web site. Here it is
"The Nikon MB-40 Multi-Power Battery Pack accommodates eight AA (alkaline, lithium, or Ni-MH) batteries, or the Nikon EN-EL4 Rechargeable Li-ion Battery. The MS-40 Battery Holder comes with the MB-40. With the MB-40 attached, film can be advanced as fast as 8 fps.
When using the EN-EL4 battery, the Battery-Chamber Cover BL-3 must be used.
The MB-40 is also a vertical grip, and features a vertical grip shutter release, an AF start button, and Multi-selector and Command Dials for more comfortable and responsive shooting."
Oct 15, 2014 | Nikon Used MB-40 Multi-Power Battery Pack...
I have a an35n ultra v1.1 motherboard I power on my tower,it does power on but it wont post I dont see anything wrong with cap's cpu was tested and checks out Power supply is good Tryed a new video card...
Hello Phenom, Hi.... to properly run/test a motherboard, you need to make sure this parts are good with no doubt functioning. 1. the power supply, 2. Memory, 3. keyboard, 4. Processor with FAN 5. PC speaker(built on-board or the thumb speaker) and 6. monitor How to test. First remove all motherboard connections. Now reconnect the following. 1. make sure that the power supply 20/24 pin is connected properly to the motherboard (and please test this power supply before making connections. To test independently short green wire to ground and plug the unit. you should see the fan spin) 2. make sure that the 4 pin 12volt power connector is also plug in nice and tight. 3. clean the memory slot using a clean paint brush and the module (DDR/2) terminals (the contacts) using an eraser, 4. connect the keyboard, 5. make sure there is a PC speaker connected. 6. connect the power switch of the front panel, 7. Connect a monitor on the VGA port 8. Power on the PC. 8. Look at the keyboard lights 3 LED momentarily. num lock + caps lock + scroll lock and after several seconds 1 LED light, num lock only. If you reach this part you should also hear a beep. then the POST will appear. If you don't reach this part, start again from the top. do this several times. Still no response? you motherboard is bad.
Jan 07, 2011 | Shuttle AN35N Motherboard
Problem with the EliteGroup ECS A790GXM-AD3 AM3 AMD 790GX HDMI ATX AMD Motherboard Help please, no power What is the recommended Power Supply Wattage for this MB i am using a Diablotek 550 Watt. I checked...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 15, 2010 | EliteGroup ECS A790GXMAD3 AMD 790GX MB w...
No power at all. what and how to check
Unplug everything but the motherboard and front panel connections. Remove any cards (even the video card) and ram and see if the system comes up (you should hear error beeps and get lights). Install the ram next and retry if the power is up. At the point where the disappears you have found the bad component/ device. If no power lights with everything disconnected but the processor the power supply is bad or mother board is bad. The switch on the power supply is set for your line voltage correct?
Oct 24, 2009 | OCZ StealthXStream / 600-Watt / ATX /...
Asus M2N / Antec SP-350
Things to try:
1. Check that the cpu fan is properly connected to the correct port marked CPU FAN.
2. Make sure the power cables are connected correctly to the motherboard.
3. Test the button switch with a multi-tester to make sure that it tests good.
4. Make sure the power switch is connected to the correct pins on the motherboard.
5. With the computer off pop the cr2032 battery out and pop it back in after a few minutes.
6. Test the power supply with either another motherboard or a power supply tester.
7. Test the motherboard with another power supply.
8. If all else fails replace the motherboard I have had a bad one from time to time even out of the box, and if you have a spare cpu you may want to test with that also. Cpu's hardly ever go bad I think I have had two go bad ever, not counting power surges and storm damage.
Sep 10, 2009 | ASUS Computers & Internet
No power to motherboard Shuttle AN35n ultra
Hi there
Try One of the following steps:
  1. Flash Youre MB BIOS.
  2. make sure that CPU Fan is working OK.
  3. Is the CPU attached to the MB correctlly.
  4. Is the CPU Fan base and scrowse faremly scrowd and positioned on the MB.
  5. Chec MB in/pot power pins connections.
Hope That will Help.
May 16, 2009 | Shuttle AN35N Motherboard
Tyan S5396 and Thermaltake 1500W
tyan i5400xt.. to test for ground.. pull the board from the chassis and test with a different known good power supply
if the boot works... then you have a power supply issue...
does the board have a post code lighted signal ???
if so.. a bad power supply should goto FF error code
verify you have enough power on the cpu rail with your power supply specifications also
be sure you have all cables 4 pin 8 pin and 20/24 pin connections done correctly.. lastestly check if the board is touching the chassis edge anywhere... could cause a ground
also take and loosen all the MB screws from the chassis.. just let it hang there this will test the grounds needs the screw connections
mark@omces.com
tyan specialist
Oct 31, 2008 | Tyan S5396A2NRF Dual LGA771 XEON5000 5100...
SG33G5 & Radeon x1950 pro 512mb
sg335g5 mb. only supports 385mb video memory
Nov 11, 2007 | Shuttle (SB83G5) Barebone
Shuttle XPC XB51G Barebones - no power
I think you will find your PSU has gone faulty, they are very cheap these days, I would guess at the PSU and replace it "On Spec" with a similar one. Remove the four PSU screws around by the Fan at back. Unplug it from The motherboard noting connections, can only go one way thogh. Take the PSU to ya local repair shop and get another... put new one in connect up to MB and power up. If ya lucky.. ya solved ya problem. Or better still see if you can test it with another one B4 buying another.
Aug 08, 2007 | Shuttle XPC 250W Power Supply (CSSHMIS10)...
Shuttle AV40 Motherboard Logo
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
