Question about Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17 in. Flat Panel
Come on goese to power save mode how do i get it out of safe mode
  • gmannwcoast Aug 20, 2008
    Problem: Dell E172FP 17 in. Flat Panel
    posted by gmannwcoast on 08/20/2008
    come on goese to power save mode HOW DO I GET IT OUT OF SAFE MODE SO SCREEN COME BACK ON AN MOVE ING MOUSE DOSE NOT SOLVE PROBLEM
  • Anonymous Dec 29, 2008
    i had the problem but now. it just goes black with the power light still green.
    stays on for about 5 seconds.
    reasons i have found for this:
    Aparrently there's a problem with the integrator(?).
    was bleeding AC power onto my system board!(leaking AC power through the monitor cable)
    hope this helps
  • 555 Answers
Is the display connected?
If the computer is ON and the display is connected to the computer, the display will get out of energy save mode. If regardless of that you can't get your display working, sounds like you got a broken inverter driver.
Here is a website explaining the issue:
http://josepino.com/?howto-repair-dell
Posted on Sep 04, 2009
I have a dell monitor (2002) and all of a sudden when I try to turn the computer on I get blinking yellow light and (took to Best Buy and computer is fine) when I hit the buttons on monitor I get (power...
Hi Tomccaw,
In this case your monitor is working fine. Your system is going to power saving mode. To resolve that remove your RAM and insert it. It will fix your issue.
Jun 15, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
E172FP (Black) 17 in. Flat Panel LCD Monitor: Dell monitor problem, its the power save mode agai...
First, try it on another PC, check or try another VGA cable, if it still does not work then you need to open it up. Dell monitors are known to have bad solder connections, bad caps. See my photo albums of failed Dell monitors to get some idea what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 18, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Screen goes black while in use
If your monitor it's good the reason may be that the settings of the refresh rate is to high for your monitor. Try to enter in Safe Mode (Press F8 key before booting in OS and from the menu choose Safe Mode) and then from Control Panel try to remove de video driver and then restart the computer. After restart, the OS will detect your video card as standard VGA card. After that install your video driver again.
Apr 09, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Can you set up two Dell E172FP 17" flat panel LCD monitors with an latitude D630 docking station?
Yes, but you will need a dvi to vga adapter.
Or one of the monitor must have a dvi input.
Mar 09, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
At start up screen goes black and get message can
Native/max resolution for this Dell is 1280x1024, try this setting.
Feb 19, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell e172fp flat screen
check the power if 110 volt or 220 volt
Jun 05, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Unable to get monitor out of power save mode
turn your moniter off waite 30sec back on this should get your screen on. Try this Rigth click on your desk'top >properties
>screen saver, click Power then change the turn of monitor tab
Jan 24, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
203 people viewed this question
Alun Cox
