Screen i cant see my screen its went blank as if the bcklight has failed is there anyway to reolve this I have an HP ZE2113us that I purchased from my god-daughter (helping out a broke college student!) The hard drive had crashed but I easily replaced it and added additional ram and used the laptop for a good year before I lost the display the other day. I had never had a problem with the display before, but I think i may actually have contributed to the issue by partially closing the lid with something blocking it open. i planned to go back to continue working but became sidetracked and didn't get to it until the next day (today). When I restarted it, I could faintly make out the start up sequence and was able to see just enough to login, but it was futile to try to work with it. I tried to adjust the contrast, but that didn't work, so I hooked it up to an external monitor to test and I could see everything perfectly. I have read several comments/suggestions which refer to the power inverter and/or LCD backlight lamp. I am pretty computer literate and knnow how to build and repair PC's so I can understand the situation regarding the lamp burning out, but could someone supply an explanantion of the power inverter's function? It would probably help me determine whether it is the lamp or the inverter itself. Any assistance would be welcome. Thanx!
    Brigadier General:
  • 6,966 Answers
To give you an idea:
  • the backlight are CCF lamps (cold cathode florescent). Due to size/ design, they are roughly 2mm in diameter and length spans the width of the display area, they are often shielded/supported by a similar length J bar/bracket both for reflective purpose and structural support. If on the instance the lid was closed with an object obstructing, then it is very possible that the lamp was broken. This could be visually verified once the display panel is exposed;
  • the inverter is basically a DC to AC converter. It takes in the supply DCV of the laptop and converts this DCV to high frequency high voltage supply to power the CCF lamps. Often the inverter is an elongated PCB with a HF transformer at one end that immediately goes to the CCF lamps through a 2wire connector. The inverter could be electrically checked with the use of an ACV meter.
  • Both are readily available online.
  • It is often more of a challenge opening the two halves of the lid than determining the fault;
  • In some instances, dried up/blistered capacitors can cause no oscillation (hence no HF/HV output);
  • there are also instances where it is the flat cable that might have been stretched and therefore power is not available to the inverter;
  • since the inverter's output is HF/HV, pls treat it like the flyback of a small TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 20, 2008
Display screen is blank??
After eight years of service, it is possible that the display has failed. You will have to weigh the cost of replacing the display against the probable maximum lifetime of another two years for the machine.
Apr 23, 2016 | Maytag Neptune Washing Machines
Hi i have got an hp pavilion tx2000.3 days ago the screen went blank and is black.the power seems to be ok but screen remains black and cant start n open.
try plugging in another screen using the VGA slot at the back (or side) if this works then there will be a hardware issue with it and it would need to be sent away for repair with HP unfortunatly
Brentwood IT
Sep 25, 2009 | HP Pavilion dv6000z Notebook
Received message at started of "system failed to cnnect", clicked ok and screen went blank. I hear system working but screen remains blank.
Try removing your battery for about 5 mins and place it back. This time it should start properly.
Thanks
Aug 09, 2009 | HP Pavilion DV6910US Laptop
Monitor just quits,
you posted to a wrong place, to an empty stop, its not a response post at all. but....
old old VS19 , with CCFL inside, (oops)
the OSD is dead, proving the monitor is dead.
the CCFL laps are bad or the board is a bad.
not all boards (PCB) fail for caps, unless,made in the bad china cap era....
i buy my caps at Mouser ,x10 better quality btw.
there is more to this board than just a cap
photo is of early L1503.
best place to look is get a used board from Ebay.
HP does not sell this board now, its LEGACY.
nor do they sell or offer schematics (lacking that very hard to fix)
those 2 black rectangles below are the CCFL high voltage generators. ether can fail. and CCFL is dead.
use a flash light to the screen yet , while pushing the Menu key there
for the OSD display to show up???? if it does then the CCFL parts
are bad. dead backlight.
Aug 04, 2017 | HP vs19 19" LCD Monitor
Screen has gone blank. Is this common? Fixable?
HP is stonewalling hundreds of customers with this same issue. Join the class action lawsuit. http://hpplasmalawsuit.info
May 13, 2009 | HP PL4260N 42 in. Plasma HDTV
Trying to install HP J4680 AIO printer and installation fails at
jim it is ur printer driver problem because ur software is damage u need to download the driver from net. or purchase a new driver.
Mar 24, 2009 | HP J4680 Office Jet All-In-One Printer
My screen went black
If your Notebook's screen went blank you can do the following:--
1) Try booting with an external monitor. Connect the external monitor to the VGA port given to the Notebook.
Result:1 --- If the external monitor is working fine, then the problem is with LCD. If your Notebook is under warranty you can get it repaired free of cost.
If your Notebook is out of warranty you can go to HP.com and purchase the LCD screen (If you are in USA please go to this link :--- http://h20141.www2.hp.com/hpparts/)
Result 2:--- After connecting the external monitor even the display is not there, then it is the problem with the motherboard. If your Notebook is under warranty then you can avail free repair.
If your Notebook is out of warranty you can go to HP.com and purchase the Motherboard (If you are in USA please go to this link :--- http://h20141.www2.hp.com/hpparts/)
Feb 15, 2009 | HP Pavilion dv6000z Notebook
Screen
Try pressing Fn-F4 a couple times. Sometimes people accidentally enable the external screen and disable the internal one. If this doesn't work, try plugging an external screen in. If the external works then you might have a dead display.
Jan 20, 2008 | HP Compaq Presario V2000 Notebook
Hp Pavillion laptop
Can you try booting to an external screen? If it works with an external screen, sounds like either the inverter (probable) or the backlight has gone out. If there's no image on the external screen, it could be any of several things, the most likely of which is the video module.
Sounds like you got a lemon. The DV series have been good sellers, and mostly good units.
Good luck
Oct 23, 2007 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
277 people viewed this question
David Payne
David Payne
