Question about Sega Master System Console
Directional Pad I have a Sega Master System that works well almost everything works on it. The only thing that doesn't work is the directional pad on any of my controllers. I tried the controller on my friends SMS and the d-pad worked fine how can I fix my issues with the d-pad??
  • 659 Answers
Honestly sounds like its the controller port either have to open it up and make sure everything is connect correctly around it or even blow some air into the ports to blow anything that might be blocking they come loose now and again over the years of use.
have you tryed it on the controller port 2 yet? if not try that and see if it works on that one.
Posted on Sep 06, 2008
Obscure Pc game
See if an obscure pc game lets you configure buttons manually. If not, play a different game.
May 11, 2013 | Microsoft Xbox 360 Controller
Control pad
Control pad's are generally all or nothing devices, they either work or they're dead. However with a console of this vintage there are a few things that can cause this kind of issue and therefor a couple things you can do to try and resolve it. 1: Clean the serial ports and plugs (the ports and plugs that connect the pads to the console) with an air duster. Air dusters are cans of compressed air with a long nozzle and are available from most computer, electronics and hardware stores. Clean both serial ports even if you're only using one. 2: if cleaning doesn't work try unplugging the power cable, removing the console's casing and touching a hot soldering iron to the base of each of the pins that connect the serial ports to the PCB (Printed Circuit Board) in tern to re-solder them without using any extra solder, if you find that you do need more solder be sparing. You can see a pictorial guide to disassembling a Sega Genesis here www.takeitapart.net/archives/sega-genesis/ click the pictures to see a larger image. Lastly if you know anyone else who's in to retro-gaming swap a control pad with them to see if your pad works on there Sega Genesis and there pad works on yours. If you find the pad actually is dead it's not the end of the world, there are a few around on popular auction sites, retro gaming sites and specialist game stores pretty cheaply.
Aug 23, 2007 | Sega Genesis Console
Down arrow key not working properply; cursor keeps moving up on its own: sometimes doesn't respond to down arrow key being pressed
u probably have sticky stuff and dirt in the directional pad, try this:
take the battery out, make sure the power is off, pour a little alcohol in the the crack of the directional pad, then press the directional pad in the different directions to loosen it up, finally let the psp sit for a few hours til the alcohol dries (or blow in it) that sould loosen everything up, if that does not work you will have to open the unit and clean the pad thorougly...
Jul 13, 2009 | Sony PlayStation Portable (PSP) Console
Directional buttons work fine, until I start playing a game
Ok. navigate to system settings and scroll down to RESTORE SYSTEM SETTINGS, after that turn off your psp and wait for about 3 minutes and turn it back on.
Write back if this doesn't help.
Apr 18, 2009 | Sony PSP (Piano Black)
Directional buttons
its dirt man.. take your console back to where you bought it so that they can check. There are no other reason why your d-pad wont work.
Feb 01, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP Directional Pad does not work
sell it. thats a mother board problem it costs 110 buvks to fix. ill buy the psp
gabrielsimut@yahoo.com
Jul 07, 2008 | Sony PlayStation Portable (PSP) Console
Directional pads not working
the new one have a problem with bracking send it to the people who made it
May 19, 2008 | Sony PlayStation Portable (PSP) Console
Sega master system 2 setup - can't get picture
most likely problem is that your tv isn't tuned to the sega - you can fix this by going into the tv menu and tuning it manually
Mar 31, 2008 | Sega Master System Console
Screen broken
From main screen:
Either 'a':
Press 'down' on your directional pad to open up the phonebook (default setting)
OR
Press the menu key and scroll down to the phonebook entry (I'm not sure if you remember where yours is, as I changed my menu around. My phonebook listing is the first one. Dunno if this helps at all)
Then, once you are viewing your contacts:
Press the menu key.
Press 'down' on the directional pad eleven (11) times to highlight 'copy'.
Press the center of the directional pad in to select the highlighted menu item.
Press down on the directional pad once to highlight the 'all to SIM' option.
Press the center of the directional pad in to select the highlighted menu item (MERGE)
OR
Press down on the directional pad once to highlight the 'OVERWRITE' option, and then press the center of the directional pad in to select the highlighted menu item.
Depending on how many contacts you have, this will take about 30 seconds per 100 contacts.
Jan 04, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Touch screen will not work
try to reboot it, there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Dec 12, 2007 | HP iPAQ RZ1710 Pocket PC
Sega Master System Console Logo
105 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
