I'm having problem with my myspaceIm connecting. It want let me connect. I sent the problem to yall and no one have contact back. It's says that it's a problem with my internet or firewall. I've check with my Internet provide and disable my firewall and still the same thing. Can you help me are let know someone who can.
    Problem Solver:
  • 42 Answers
Hi, after disable the firewall, pl check that no antivirus programs are blocking the port for myspaceim. try to uninstall then reboot the system, and install again. this should work.
Posted on Aug 20, 2008
SOURCE:
The sound wont work with this tv as its connected to the pc. just bought the tv today, tv's model is Sansui SLEDVD244. plz halp me yall :-(
You might have to download and or install the correct drivers. A lot of stuff comes with the install for the needed drivers. Might it of had a cd with it.
Mar 31, 2013 | Audio Players & Recorders
Maytag MDG8057 dryer won't heat. I unplugged the dryer to use the outlet for something else, plugged it back in, and now it won't heat. Any connection to unplugging it? If not, potential...
Did yall move the dryer? The ignitor is very brittle. Moving a gas dryer sometimes breaks an ignitor with a little age on it.themobilian_2344.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2011 | Maytag Dryers
Washer will wash but wont drain or spin.
The motor on your machine has the pump mounted on itthemobilian_1699.jpgWater can't be expelled if the washer motor cannot spin. One direction is for wash and the other is for pump out and spin.
SO... if it won't spin or drain the that lid switch is probably broken. They put a lid switch in there to prevent folk from grabbing or messing around with them clothe while that washer is in full blast.
To get to them lidswitch yall need to flip up the console and expose the connectionthemobilian_1700.jpgthemobilian_1701.jpgthemobilian_1702.jpgthemobilian_1703.jpgthemobilian_1704.jpgthemobilian_47.gif
Them lid switch connection got 3 wire. 2 hot wire and one grounding wire (green mounted to frame). Yall jumper them two hot wires and see if that puppy takes off. Don't be leaving it that way in case yall have peeps that would get hurt messin around with them washer while spinning all full blast.
How it works
Mar 04, 2011 | Kenmore Washing Machines
Code F 11
F11 Serial communication error
Communication between the Central Control Unit (CCU) themobilian_547.jpgand the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
Might jus be something done come loose at them connections
remove the base panel and there you will find them tech sheet for that machine.
It will show yall how to do them test on that fancy front banger.
The Happy hippy has a nice VIDEO he made what shows yall how HERE
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
That's all them smart pills we can come up with right now.
Happy Holidays!
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Y have problem whit the internet it to slow
dude that is in terms if your ISP.
but before you call your isp try to do this:
Scan for viruses ( but first update the antivirus software you use to the most updated virsion )
CMD codes ( Cant connect to Internet )
1. Go to command prompt
2. Type-in Ping 127.0.0.1 = Lan Card address
3. Get the value of the pockets Sent, Recieved and Lost.
4. If the value is ( Sent = 4, Recieved = 4 and Lost = 0% ) Then the lan card and wireless card is working fine and the problem is with the ISP = Contact ISP
OR
No Connection using router
2. Type in ping 192.168.0.1 or which ever the address of your router.
4. If the value is ( Sent = 4, Recieved = 4 and Lost = 0% ) Then the lan card and wireless card is working fine and the problem is within the Router configuration. = Advice the CX to Contact the Router manufacturer or ISP
Aug 21, 2009 | Acer Aspire One PC Notebook
LG enV 2 not turning back on
If possible take it into your cell providers store and ask them to check it. They should be able to do a battery test and a software check for free of charge. If they are no help check the brass contacts on both your battery and phone. They might be making intermittent contact or be corroded. Also check for water damage. There should be a small sticker, if its pink its water damage. It could also be a defective battery, but don't buy one. Try to find someone that has one and borrow it to test. Good Luck
Apr 18, 2009 | LG enV2 VX9100 Cell Phone Car Charger
Xbox 360 wired controller wont connect NOT WIRELESS!
Hello mate, all you have to do is to go to a fixing shop and they will fix your xbox for around £50 , i know this because i have done this with my xbox. Thanks
(Could you leave me a vote and good feedback.)
Mar 12, 2009 | Rockstar Games Grand Theft Auto: Vice City...
No internet setting
You need your Service Provider to send you Internet Settings.
Ring them up and ask.
Once they have sent them to you, save it and set as default internet connection.
Oct 10, 2008 | Sony Ericsson P990i Smartphone
Canon mp 460
reinstall the drivers b4 u connect the printer
Jul 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
