Question about KitchenAid KHWS01PMT Front Load Washer
Control locked My control panel is stuck in the "control locked" position. Any ideas on how to get it unstuck?
    Genius:
  • 1,028 Answers
Look for button with lock symbol beside it hold button 3-5 secs or until light go out
Posted on Aug 21, 2008
Get barrel unstuck
there is lens lock slider, slide to unlock the zoom.
May 19, 2013 | Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
How can i fix my dryer. I it stuck on control lock
Press and hold the End of Cycle Signal button for 3 seconds or until the Control Locked indicator turns off to unlock the control. This button actually has the marking below it that says " Hold for 3 Seconds to Lock/Unlock Control". You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle Signal button and unplugging the dryer for at least 15 minutes. Let us know if the problem persists.
Jul 13, 2011 | Whirlpool GEW9250 Electric Dryer
Door locks stick on and drain battery
One of the switches must be bad or stuck in the lock or unlock position. Try functioning each switch several times in both directions to see if you can get it unstuck or maybe help isolate which switch it is.
May 02, 2011 | 1996 Jeep Cherokee Sport
I have an error code 68 what is this?
The error code means a key is stuck; enter the service diagnostic mode and perform the key test to determine which key is stuck. Once the key is determined, try to unstuck it; replace the Electronic Control Board (Part Number AP3851146 if the error code continues to appear after the button is unstuck.
Press and hold simultaneously the Select and Cancel buttons for six seconds to reset the control then immediately after the buzzer sounds, turn the cycle selector knob 5 clicks counterclockwise to position the cycle indicator light second (Touch Up) from the bottom.
Press and hold the Options and Cancel button simultaneously for two seconds to enter the service diagnostic mode. The buzzer will sound three times and all of the LEDs will flash indicating the service diagnostic mode has been entered successfully.
Rotate the cycle selector knob 4 clicks to the Heavy Duty cycle; the motor runs with the heater off. The buttons can now be tested. Press each button and all corresponding LEDs should flash; otherwise the button is stuck or a faulty. Unstuck the key and perform the key test again; replace the control board if the problem is not resolved.
Access to the control board requires the removal of the top panel and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the top panel to the rear of the dryer then slide the panel rearward and lift it off the dryer.
Remove the four screws, two on each side, securing the console to the front panel then flip the console forward. Disconnect the wires from the control board and lift the console off.
Remove the five screws mounting the control board to the console and lift the control off. Remove the control board's rear cover by releasing the two locking tabs the flip the cover off the control board. Try to unstuck the faulty key and reassemble the dryer in reverse of the disassembly steps.
Hope helps.
Apr 14, 2011 | Frigidaire GLEQ2152ES Electric Dryer
The control panel on my lexmark all-in-one intuition S505 printer is stuck in the upright position and will not go back down...how do i get it unstuck?
I had the same problem for a week, and I share your frustration. Under the panel, in the center, is an elevated piece of plastic with three ridges. Push this in (you'll be reaching your hand in, so you're actually pushing up towards the back of the panel) and the panel should slide down. Good luck!
Mar 10, 2011 | Lexmark Office Equipment & Supplies
Error code E 68
A button is stuck and it needs to be unstuck. Enter key test mode during the diagnostic test mode to determine which keys is stuck.
Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control.
The buzzer sounds then immediately turn the cycle selector knob counterclockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds then the control enters diagnostic mode. The buzzer sounds 3 times and the LEDs flash.
Turn the cycle selector knob clockwise the second position from the top. The drive motor runs and the heat source turns off.
The buttons can now be tested. Press each button and the corresponding LEDs turn on. You should be able to find which button is stuck. The Options and Select buttons turn on the same set of LEDs and also the Cancel and Start/Pause buttons.
Access the control and unstuck the button. Disconnect power and remove the top panel by removing the screws attaching it to the rear of the dryer. Slid the panel rearward and lift it off the cabinet. The screws attaching the console to the cabinet are exposed. Remove the screws and disconnect the wire harnesses then remove the console. The control can now be removed and the buttons are exposed. Unstuck or clean the stuck button contacts. It is recommended to clean all other button contacts to prevent the recurrence of the same problem in the near future.
Oct 28, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Stops working with code e68
The error code means a key is stuck; enter the service diagnostic mode and perform the key test to determine which key is stuck. Once the key is determined, try to unstuck it; replace the electronic control board (part number 134557201) if the error code continues to appear after the button is unstuck.
Apr 27, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Panel instruments do not work
sounds like he accidently disconnected a wire bundle connector under the dash somewhere. It could also be a faulty or disconnected relay from the same area.
Jan 05, 2009 | 2002 Honda Odyssey
KitchenAid KHWS01PMT Front Load Washer Logo
89 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
