Question about HP Computers & Internet
The printer was working it has printed out about 12 pages then it stopped ,there is no paper jam ,I had a tech around he checked it out ,then uninstalled it ,then installed it again it will not print out a test page ,I purchased it on the 9/7/08 at **** smiths
    Problem Solver:
  • 42 Answers
Pl reinstall the driver and check it again, if dosnt work then approach vendor for replacement under warranty/guarranty.
Posted on Aug 20, 2008
Paper continues to jam
check the paper actuate of the sensor if it o.k check the sensor if its clean
Jun 24, 2014 | Gestetner C7425DN Paper Feed Roller...
Paper jams every 3rd or 4th print around the printing drum
If it is an older printer (many pages printed) the pickup rollers are most likely worn out. As the printer heats up, the worn out rollers heat up and don't work as well causing the jam after a few pages.
This also happens with a thicker paper... the paper is too thick for the printer.
Oct 23, 2013 | Lexmark E260dn Laser Printer
Inconsistent printing
In the printer's dialogue find the print pages number. Print page from/to and select 20 pages chunks. In effect print only part of the document at a time. Add all chunks together in one pile. Work around I know, but it works.
Aug 02, 2017 | Brother HL-2130 monochrome laser printer...
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
Printing from a computer, get paper jam, clear it, then the printing sarts over from zero again, so get too many copies. Any fix in the software? The counter on the machine doesn't operate when...
You can work this around by using a little manual labor. Whenever the paper jams and doesnt continue from previous page, you can unplug the printer from the electricity. (not just the on/off button). This way it loses the document that was printing from the memory. Then you can send the doc for printing again by designating which pages to print.
ex. if your document was stopped at the 12 pg and it has 20 pages.. go to print> and then choose which pages to print i.e. 13-20.
I hope this helps.
May 22, 2011 |
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Paper jam after first page prints.
Most likely something in the printer or software is set to an improper paper size. It's saying jam because it prints the first page and registers an incorret size.
Check BOTH the printer itself and the program you're printing from.
Feb 26, 2009 | Dell 1600n All-In-One Laser Printer
Printer says paper jam and stops- but it is not jammed
your description indicates you need to thoroughly check printer for any bit of paper ........rolller too has to be checked so that paper is moving smoothly ......
Feb 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Laserwriter 12/640 PS
hello the printer paper pick-up rollers are bad. this why you caanotuse the pick tray. the solution now is to set the printer to default and clear allstuff off memory. read the instruction below: LaserWriter 12/640 PS: IBM PC or Compatible Troubleshooting This article explains IBM PC or Compatible Troubleshooting. A message on the screen says the printer can't print. If you get such a message, try the following steps. Make sure that the printer is turned on. Check the network or parallel cables. Make sure that the PostScript printer driver has been installed. Nothing is printed; no paper comes out of the printer. If you don't get any response from the printer when you try to print a document, try the following steps: Check the Installed Printers list to see that your printer is selected. Try printing the document again, but choose Download PostScript Error Handling in the Printer Setup PostScript Options dialog box. Check the Paper Out light. If it is on, add paper and replace the paper cassette. If it is blinking, make sure the paper cassette is securely in place. Check for a paper jam. Check the printer cables. Check the position of the port communication switch. The port may have been turned off or the Interpreter settings may not be correct. Reset the communications settings to their factory default values by setting the communication switch to the Reset (out) position. Turn the printer off and back on again. Set the communication switch to the Normal (in) position. Turn the printer off and back on. Check the startup page. Reinstall the printer driver. For Windows 95 users, check the following additional item: Open the Printer folder, select the printer, and click Properties. click the PostScript tab and click the Advanced button. Make sure that ASCII data and "Send CTRL+D after job" are selected. For Windows 3.1 users, check the following additional item: Open the Printer Control panel, select the printer, and choose Setup. Select the PostScript tab in the Properties dialog box. Make sure that Protocol Options is set to Default if using the parallel port, or None if printing via NetWare. Sometimes Printing the First Page Takes Longer than I Expect The LaserWriter 12/640 PS automatically goes into an energy-saving mode after it's been idle for a while. When you print while it's in this mode, the printer takes about a minute to warm up before it can print the first page. The printer is properly connected and configured, but printing is garbled or displays unwanted characters. Check the communication switch and make sure that the Interpreter is set to the correct value. If you are printing a PostScript document, the Interpreter mode should be PostScript or AutoSelect.
Aug 08, 2007 | Apple LaserWriter 12/640 PS Plus Printer
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
