Question about Gateway Computers & Internet
I purchased computer in April. All devices attached worked perfectly. Started experiencing problems with keyboard, non responsive at times until it completely died. Called for service and was told it was the motherboard. It took a more than a month to get my PC back. I have reinstalled all my programs and now my printer will not work no matter what I do. There is a message indicating it is offline. All plugs in place with a lit green light on the printer. How can I get this printer to work now. It worked perfectly before the repair.
    Sergeant:
    Champion:
  • 246 Answers
Please try to reinstall the printer drivers
Posted on Aug 20, 2008
Samsung 700Z5A keyboard input errors
A computer keyboard is a vital component of the computer system. Without a properly working keyboard, your computer is essentially rendered ineffective. If the keyboard is frozen or not responsive, it is experiencing an error known as a "lock out" error. There are various reasons for this error, so you must undergo a process of elimination to figure out the root cause.
Make sure that your keyboard is properly connected to the computer system. Ensure the keyboard's plug is plugged into a USB port. A keyboard error will occur if the keyboard is not attached to the computer or if it is loosely plugged into a USB port. If this is the case, the keyboard will not be recognized and rendered useless. Press the "F8" button repeatedly as the computer boots up. This will take you to a menu in which "Reboot" is one of the options. Select the "Reboot" option. Rebooting your computer should clear up errors in the computer system that might cause your keyboard to lock out. Click the desktop's "Start" button. Right-click the "My Computer" icon and click "Properties." Click the "Hardware" tab and click the "Device Manager" button. Scroll through the "Device Manager" list and right-click on "Keyboards." Click "Properties," then click the "Driver" button. If the keyboard is classified "Disabled," click the "Enable" button to activate it. If this does not help, click "Roll Back Driver" to revert your keyboard driver to its last working state. Rolling back the driver should rectify keyboard errors. Restart your computer system to finalize the process. Hope this helps.
Dec 13, 2012 | Samsung Computers & Internet
Print screen
Observe the condition to ascertain condition. For example, connect the keyboard to computer to ascertain response. usually with peripheral devices, connections to computer should display results of compartibility else mesages is malfunction missing media recogniseable. In the situation that the keyboard is malfunctioning as missing media is indicationof incompartible to computer. For example, wireless keyboards require adaptors devices attached to computer to function where the computer has to be wireless compartible. In the situation where a cables wired keyboard were attached to wireless computer would be missing the adaptor. Where a wireless keyboard were attached to a computer that least wireless with an adaptors would least produce any results. Circumpectively, the computer with wireless capabilities requires a wireless adaptor that recognies a wireless built keyboard.
Feb 22, 2011 | Dell SK-8125 Keyboard
When did the system rebooted and started the boot sequence, the screen showed only one line and froze. Then I took my flash drive and rebooted again. then again it does not start, black screen and no...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Dec 21, 2010 | Foxconn K8M890M2MB-RS2H AM2 VIA K8M890...
I can not get my computer to recognize that the camera is attached to download the photos from the camera to the computer. I just purchased the camera in April and was able to download to the computer one...
check your computer usb port if working properly by plugging other device that working. or installed your camera to other computer to check which one caused problems.
Jul 02, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Sony PS3 wireless keyboard non responsive only blinks green light
Hit the Reset Button on the Keypad (Its a little hole on the left of the back). It works all the time.
Apr 25, 2009 | Sony Playstation 3 Wireless Keypad/Mouse
On booting up, computer can not load keyboard system.
One possible problem is that your PS2 keyboard port at the back of your PC is ruined. In time, those so called "outlets" become loose specially the ones with cables which usually got pulled or tangled and make the port strained and the contacts get loose.
If that is the case, you might need to replace the keyboard port, or just stick with your usb keyboard.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
Windows XP problems and missing AutoChk.exe file
Registry error happen all the time it happens when a spyware program mistakes a windows file for spyware then deletes it the only right way to fix the problem is to compeletly restore ur pc to ethier the last known restore point or compeletly restore it to the time it came out of the box
Looking to help u
Shaun
Nov 14, 2008 | Acer Aspire 3000 Notebook
Ovens
The F1 error message usually means a short somewhere in the touch panel keyboard. There has been a rash of problems with keyboards. Most of the time there is a simple fix that can be used. Please see my post of April 14, 2007 in response to the problem posted by OVENMAN on April 12, 2007. There you will find a suggested solution which has helped hundreds of folks who have had error messages with GE and Kenmore ovens. If this fix doesn't work, you will need a replacement touch panel. There is no practical way to repair the keyboard in ovens.
Apr 17, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Computers & Internet Logo
24 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
