Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 won't print
Error message: More than one ink tank (yellow) is inserted. This is not the case. How can I solve the problem?
Roslyn
  • 2 more comments
  • Anonymous Aug 24, 2008
    Indicates I have more than one magenta ink cartridge installed (which is not the case) and won't print. Have tried a new magenta cartridge, taken all cartridges out and put them back in, turned printer off etc. in fact tried all the basic things but to no avail.
  • 94subaru Aug 25, 2008
    Same problem but message says 2 black installed. Not the case wont print
  • Anonymous Sep 01, 2008
    Help, I have ip4200 Canon printer That will NOT print with yellow or light pink, I have cleaned the ink printer heads washed them under running water 4 to 5 times. All other colours print ok.
  • Anonymous Sep 10, 2008
    It's the yellow for me too. Various suggestions on the internet haven't worked in the long term.
I had the same issue with my black cartridge. I changed it for a new one and bingo. it works. Expensive solution though, especially if it reoccurs.
Posted on Sep 19, 2008
I solved the problem (I hope more than temporarily) by going out and buying a new yellow ink cartridge. The new one seems to be working, but the cartridge that generated the error message was brand new, too - hardly a satisfactory outcome. I worked out that buying a new cartridge would be slightly cheaper than signing up for one of the Canon support plans. As you can guess, this experience does not augur well for me buying more Canon products in future.
Roslyn
Posted on Aug 20, 2008
Installed new ink on ip4200. Black will not print on test page "horizontal box", other colors print. Any suggestion on why the black won't print? Thanks.
The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (A), it is properly removed.
  3. If the orange tape is as shown in Figure (B), remove the remaining tape to the level shown in Figure (A).
  4. Make sure each ink tank is snapped into the printer.
Aug 26, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Replaced two ink tanks in my pixma but the lights will not flash
You cant realy do anything, i had the same problem whit my IP5000.
I tryed everything but nothing helped, after speaking whit canon here in sweden they told me to let it be, after next tank instalation it will disappear and you printer will be as usal again. Canon told that the problem is on the chip on the tank. When the printer tell you that the tank is empty or not right just press the blinking yellow button on the printer and hold it for at least 5 seconds.
Good luck
Dec 04, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma ip4200 printer, error 1414
Hello there,
I've gotten in touch with Canon and have something a little different to try. At the very least the error should change. (Sorry, gallows humor). Please read this entire response before taking action.
After the upcoming test procedure, I have included a link and procedure to contact Canon tech support. The assure me they will replace any faulty tanks.
The purpose of this exercise is either rule out ink tanks that are behaving or isolate the one(s) responsible for the 1414. You should write down the results of this test. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
Click here for the Canon PIXMA iP4200 support page
Then click on e-mail support.
Fill out the form.
Under description, supply the following info:
Error 1414 Ink tank problem on my Canon PIXMA iP4200
The error won't go away.
I have replaced the <color in question> tank, reseated it, yet the error remains.
You will also need to list what inks are being used in the printer. State the type of ink that is being used and the order that the tanks are installed in the print head.
Provide the exact part number (such as BCI-6C, BCI3eBk, etc.) if possible.
The Canon support rep assured me they will be glad to replace the malfunctioning tank(s) for you at no cost. Please
respond with the results, and specify the ink tank(s) that were not recognized correctly.
They responded quickly, professionally and apologetically. They want to help get this resolved for you.
I hope this helps end the frustration you must be feeling. If you need additional help or clarification, click the ASK button.
Mike
If you could take a moment and rate this response, I would appreciate it.
Jun 30, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Ink light flashing
whip the cartridge circuits with the tissue paper, if the problem occurs the same thing than this is the service station error mean s the software has to be installed again
Mar 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printer
Sounds like you head has gone. JO
Feb 07, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
IP4200 duplicate ink tanks.
Hello there scubadave,
I've gotten in touch with Canon and have somethinga little different to try. At the very least the error should change.(Sorry, gallows humor). Please read this entire response before takingaction.
After the upcoming test procedure, I have included alink and procedure to contact Canon tech support. The assure me theywill replace any faulty tanks.
The purpose of this exercise iseither rule out ink tanks that are behaving or isolate the one(s)responsible for the dupliucate error. You should write down the results of thistest. Please perform the following:
3.Confirm whether the printer recognizes the installed tank properly. Ifit does, it will indicate it does not detect the other ink tanks, asthey are not currently installed in the printer.
5.If the printer at any time indicates two of the same ink tanks areinstalled, the cause will be the last tank installed. For example, ifyou inserted an ink tank earlier, and you later inserted another inktank, and it said two of the same inks were installed, the cause of theissue is the last ink tank.
Fill out the form.
Error- Duplicate Ink tank problem on my Canon PIXMA iP4200
<Describe how error occurs>
I have replaced the <color in> question> tank, reseated it, yet the error continues.
Youwill also need to list what inks are being used in the printer. Statethe type of ink that is being used and the order that the tanks areinstalled in the print head.
respond with the test results, and specify the ink tank(s) that were not recognized correctly.
Remember: Good things happen to those who Rate.
Mike
Aug 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Error message 6A00
AP position error [6A00] the Sheetfeed unit or the main logic board has failed need to purge unit. Give it a good tank cleaning, possibly replace cartridges. Is it still under warranty? Have you contacted Canon?
Jun 29, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Ink tanks not lit but not empty
Hello there,
Fill out the form.
Mike
Apr 04, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
291 people viewed this question
old marine
old marine
