Need convergence output ic part # for maodel # 51v500a
  • 8,617 Answers
You can get them at the following link with free installation instructions, if your not sure which ones you need leave them a email with your model number, they respond qquickly.
http://servicemanuals.vstore.ca/
Posted on Aug 20, 2008
Convergence is bad on left side...good on right.....where convergence is good the picture is great
Re-solder convergence output ICs pins and nearby big resistors that might solve your tv picture problem and if that does not help then replace both convergence output ICs to fix the problem.
Convergence output ICs would be available in local repair parts shop or google it.
Thanks.
Feb 25, 2011 | Sony KP-65WV700 65" Rear Projection HDTV
Green color projection is lifting from the bottom left corner of the screen. Convergence adjustment for the green projection is unresponsive
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number (STK392-110. When Convergence Output failure is
detected, it’s recommended that both IC’s be changed.
Thanks for choosing FixYA, Big Irish.
Dec 22, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Convergance problem on lower half of screen.smeared red and orange double vision,but only on bottom ofscreen.top appears out of focus,but not double visioned.
Howdy,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The part(below) Number is from Toshiba, they provide good advice on replacement parts. Make sure what type of IC's your TV uses first. The cost for this repair runs around $450.00 or more.
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Nov 23, 2009 | Televison & Video
How do i fix my toshiba flat screen 57" tv when it looks like it is 3d
Howdy;
It sounds like the convergence IC's have failed.
Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is detected, it’s recommended that both IC’s be changed to the “T” type IC version. Inspect the Convergence Output IC’s for the “T” type version.
1420-B Toshiba Dr.
Lebanon, TN 37087
Fax: 615-444-7520
www.tacpservice.toshiba.com/tacp
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 61HX70 61" Rear Projection...
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
The Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Apr 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
I cannot adjust the convergence.
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Jan 23, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
version.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
After the thunderstorm...
these are amplifer ic's that drive your convergence yokes. this is not something that a consumer can do.
Mar 15, 2008 | Apex Digital GB51HD09 51" Rear Projection...
Where can I get parts?
STK392-110=CONVERGENCE IC USE TWO FOR REPLACECEMENT PART= WWW.bdent.com Product Details: The STK392-110 is a convergence correction circuit IC for video projectors. It incorporates three output amplifiers in a single package, making possible the construction of CRT horizontal and vertical convergence correction output circuits for each of the RGB colors using ust two hybrid ICs. The output circuit use a class-B configuration, in comparison with the STK392-010, realizing a more compact package and lower cost. www.partstore.com
Apr 12, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Televison & Video Logo
525 people viewed this question
Top Televison & Video Experts
